| Re: Front Suspension Geometry Malcolm
It is an experiment I will be making the slots longer towards the front to give more stiffness.
I have to machine some T slots like on the mill bed clamp kits to go in the back a thick washer on the front under the rose joint I am hoping this will stop it opening up.
If not I will have to go with holes.
The flange were the blades mount to I also used 2 dowl bolts out off the 4 that counter bore into the flange to stop it flogging the holes.
Jim |
