Old 12-22-07, 11:57 AM   #7 (permalink)
simonjrwinter's Avatar
simonjrwinter
GT40: GTD
Smile Re: SVA For unfinished cars older than 10 Years???
Chris,
Putting the car through an SVA (particularly one that has already been built...been there done that!) will probably mean re-doing a few things on the car (are the brake pipes clipped at the right intervals etc) but at the end of the day it will make the car a BETTER car, than one that has been partially assembled by someone else. You will be able to MAKE SURE things are done up to the required standard and you will know every bit of the car as a result. It may seem like a mountain to climb, but the ride down the other side makes it all worthwhile!
Simon
GTD with Southern GT rear end. Lowered engine and gearbox. 302, R21T gearbox with LSD.
simonjrwinter is offline   Reply With Quote
