Old 01-02-08, 08:23 PM   #6 (permalink)
Russ Noble's Avatar
Russ Noble
New Zealand
GT40: Building scratc
Re: Rain track setup
Sorry guys,
If you find dry bias OK in the wet then you're braking much too early in the wet which will not help turnin either. Either that or you've got too much on the rears in the dry.
Once in the corner then it's just a balancing act of gentle weight transfer, which is made more progressive by softening the suspension, but it doesn't really gain anywhere near as much as correctly set up and used brakes will.
I agree with the anti fog.
Russ
