Originally Posted by P2164 .... we found the deck lid has been fabricated with the area for the carbs off to one side by 1.25 inch. Its a SPF Mk1 and the area where the carbs protrude up through the deck hit one side. |
Seems strange to be 'offset', how are other SPF owners dealing with this?
Originally Posted by P2164 ....The manifold is windsor block manifold with spacers for the added deck height, the distributor has an extension on it for the higher manifold. I am willing to trade for EFI and Cleveland manifold for someone who doesn't like EFI. |
You have a Dart 9.5" deck height and the 351W is 9.5" too, why the need for spacers or are you saying the manifold is for a 8.2" deck 302?
The Cleveland is a 9.2" deck height are you sure that's what you need? Hall Pantera sells Cleveland manifolds; make sure you get the correct one for std port heads or raised port. They run about ~$650. Kelly Colefield sells complete EFI systems bolted on his own IR manifold casting, not cheap but excellent quality. Dennis Quella at Pantera Peformance, CO also has a nice EFI set up.
As you already have a manifold bolted to the engine why not consider using that as a basis for your EFI and selling the bare 48IDA's carbs?
