| Re: SPF questions Chuck,
The clamshell doesn't open (like the originals it is removed; up little in back and foreward).
First disconnect the connectors for lights and fans...then release Hartwell clips....lift the clip from rear as you slide it foreward watching to make sure there is clearance for the fuel caps and the lower wiper arm (may need to remove wiper blade or at a minimum some tape over it so it doesn't scratch the clip)....There are rt and l bosses on the front frame that receive metal slotted brackets bolted to the clip for locating and securing (these are adjustable for proper clip fitting)
Clear?
Steve P2125 |
