Thread: cable shifter
Old 02-25-08, 06:36 AM   #7 (permalink)
P2164's Avatar
P2164
GT40: SPF 2164 07-07
Rep Power: 3 P2164 is on a distinguished road
Re: cable shifter
As far as the sound and heat transfer, I thought of using that high temp turbo blanket, it would work and you can bond it to the metal panels, the only part I don't like is it would look like tin foil on the back of your firewall. Mike Trusty and I have discussed making a thermo pane type window for the cab. Is there some new high tech paint you can just brush on? Would be a good idea to put it on the belly pan for ground heat transfer. Summer will be here before you know it! Sure would like to hear more about the new shifter too.
P2164 is offline   Reply With Quote
