| Re: Air Bags Dave
Make sure they find it. I found before I retired from GM last year that the wire harnesses had been getting cheap because of the cost of copper. The wires used were so thin that if the harness was not routed properly wires could get stressed or pinched. Get them to put the Tech II on it to show you that everything is all right before you take it. It will be a BCM fault not an ECM on the low speed LAN and it will tell you if everything is OK (all sensors)
Dave |
