Following on from a previous posting on my build log (see below), I contacted the local IVA test station and they stated that if I turned up for the test with the re-usable type fitting on the aero-quip brake flexis on the car they would fail, as the design uses a sealing olive. However after I’d explained my interpretation of the wording, he understood my point of view, but would still require written confirmation from VOSA in <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com
</st1:City><st1lace w:st="on">Swansea</st1lace> to accept them.
http://www.gt40s.com/forum/gt40-build-logs/24109-norfolk-tornado-4.html#post269550
From the definition in section 09D of the IVA manual: “Compression joints of the type using separate ferrules are not considered suitable for joints on hydraulic brake lines other than in the case of a hose designed for a high pressure application that incorporates an inner sleeve in the compression fitting”<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com<img src=" /><o></o>
<o></o>
Having contacted VOSA, they have confirmed that this type of design is acceptable as: <o></o>
1) the design incorporates an inner sleeve<o></o>
2) the design of the hose and related fitting are designed for a high pressure application<o></o>
<o></o>
Overall, this has been a very pleasant experience in clearing this issue up. The inspector at Norwich is a kitcar enthusiast and couldn’t have been more helpful, giving me a few things I need to watch out for on the GT40 (headlamp height, fuel tank earths etc). They have tested various GT40’s and even had their own ‘cool wall’ of all the interesting cars they had tested. The contact they gave me at VOSA, again was very helpful and I have the confirmation in the form of an email. I presume that I can forward this to interested parties for reference if required.<o></o>
<o></o>
Regards<o></o>
Andy<o></o>
<o></o>
<o></o>
<o></o>
Regards<o></o>
Andy<o></o>
