IVA parts and advice needed
Hi in regards to the following can anyone lend me or advise me what to use to pass IVA .
Wing Mirrors
Headrests
Front Indicators
Square wheel nuts
Hi Nick,
For wing mirrors, Car Builder Solutions do a range that are IVA OK. I bought a cheap set that passed but the glass was poor. Have now bought an expensive convex Motorsport set from Demon Tweaks which are very good. I reckon good rear vision is an essential. I also had a set of bullet style race mirrors but they were not good either.
For headrests, I fabricated a rectangular aluminium back plate (bolted to the roll cage at head height) and had it padded and trimmed in leather
My front indicators are located in the lower driving lamp recess and you will need side repeaters visible from the rear three quarter
You will need to source wheel nuts to suit your hubs and wheels
Hope this helps
Roger
Hi Nick,
Hope this helps
Roger
Thanks Roger,
I have side repeaters fitted and a possible solution for the front indicators. Do you know what mirrors you bought from CBS. Hoping to borrow some from Southern GT but I need a backup plan.
Hi Nick,
I used a pair of these mirrors mounted on the doors and passed the test easily with the long arms
https://furoreproducts.co.uk/e-marked-mirrors
I also used a pair of motorbike LED indicators mounted in the headlamp bowl. They are small enough not to effect the beam of the headlamp
http://www.ebay.co.uk/itm/2X-6LED-Motorbike-Turn-Signal-Lights-Blinker-Indicator-Yellow-12V-NEW-/151931486834?hash=item235fd28272:g:8hoAAOSwSHZWgbaY
Can’t really help on the headrests, as I built them myself into my own seat design
I presume by square wheel nuts you mean the central locking nut to replace the tri-lobe spinner
Andy
Hi Nick,
Andy
Thanks Andy excellent, probably on your build thread but where did you mount the mirrors.
Correct on the square nuts.
At least I know they should be very impressed with my steering wheel pad / cover ;)
Hi Nick
postion of mirror as below. The passenger mirror was mounted further back to give a better field of vision
Rgds,
Andy
Ian Anderson
And if you do that you can be fined for driving without due care and attention as you are not paying attention to the driving part of the job in hand
