Steve thank you for your comments.
You mention not fitting the windows then mention I must have side windows? A friend of mine has just past IVA with no side windows, please clarify?
Thank you
Mark
Thank you
Mark
Hi Mark,
Re your forthcoming IVA test. A few things to be careful of ...... the side windows as originally supplied with an MDA kit are no longer compliant. Also don't submit the car with the side windows not fitted - that will result in a fail.
FBe very careful with regard to all the hoses on the car. Make sure they were designed for the purpose being used and are marked as such. Have supporting paperwork with you. Be careful with the rear number plate lights. If they impinge on any area that will be occupied by the number plate it will get a fail.
Be ultra careful with regard to the radius gauge tests. On the interior it is very easy to overlook something ...... handbrake levers are a classic failure. Also the bevels on some brands of gauges fail on the radius test.
Also make sure the headrests meet the current requirement. Tornado had to re-design theirs as they were deemed too small.
Please keep everyone posted as to how you get on as it helps build a pool of information.
