Mitch Krause
Hello,
I have read a few written descriptions, have not yet found any good images, so thought I would ask. For an RCR GT, in particular on the passenger seat, how have you run the seat belts.
The issue that I am seeing is that the holes that a seat belt bolt goes into are like 15.5 inches apart (the seat is 17 inches wide) and the adjusting end of the seat belt (with the metal buckle) is usually close to where the seat belt mounts to those bolts. So the issue is that there is then not room to run the seat belt around the side of the seat. If you mount without something else, adjusting would be very difficult. You will have to cut holes in your seat back (unless you put the seat a couple of inches forward. Etc.
Anyone have pics of what they did, or good descriptions to help the thought process?
Mitch
Mitch
