Go Back   GT40s.com > >
All GT40 GT40 and Ford GT Talk - All the time!
Thread Tools Display Modes
Old 1st December 2009, 09:34 PM   #21
jimbo's Avatar
jimbo
I Have No Life
GT40: Mark VI, #1149
Re: Garage flooring advice
I think that is a good choice. I used rubber tile- the kind with the coin-sized circles on it- in the engine room of one of my boats years ago, medium gray color, and because I had a lot left over I also used it to do the walls in the shower of the boat. We used to drop tools and pieces of the diesel engines on the engine room floor- it held up fine. I found out later that the same kind of rubber flooring is used in ski lodges- you know, where people come in walking in their ski boots etc etc? Holds up admirably. I have the roll-out rubber flooring in my garage and the only thing that's ever damaged it was the lawn mower- I started it up one time and the flooring was sucked up into the blade and got a bit chewed up.
Concrete floor paint works best on dry new concrete floors. My garage floor is fifty years old and the paint wouldn't stick even after we etched it with muriatic acid and nearly killed ourselves in the process (nasty stuff, but great for cleaning out waste treatment systems in boats, let me only say) After the paint on the garage floor peeled I gave up and got the rubber roll-out sheeting, its' been fine ever since.
And if it isn't your garage, I'd limit the expenditures for certain. Wait til you have your own garage and doll THAT one up.
Mark I monocoque, completed
Safir Mk I body
ZF-2 transaxle
302 w/Webers
jimbo is offline   Reply With Quote
Old 8th December 2009, 06:59 PM   #22
trevorsummers's Avatar
trevorsummers
9 Tenths
GT40: Tornado TS40
Hi guys
well I've got the flooring in and while a little darker than I'd like its pretty good. I went for rubber flooring in rolls of 10m x 1.2m. The flooring went down ok although as its not my garage I couldn't use adhesive so the joins are more visable than they would otherwise have been.
All in all though I think the flooring was good value at 150 for the lot and I have some good size off cuts left to use as matts. Garage now looks much better than when I first started and no dust in sight now
What do you think?
Before:
After:
Trev
----Trev----
www.gt40builder.com
trevorsummers is offline   Reply With Quote
Old 8th December 2009, 08:52 PM   #23
550spydr's Avatar
550spydr
6 Tenths
GT40: GTD
Trev,
It look great. Hope it works out well for you. At a good price as well...
Eric Johnson
GTD40 in Essex Wire livery
550spydr is offline   Reply With Quote
Old 9th December 2009, 09:49 AM   #24
chris h's Avatar
chris h
3 Tenths
GT40: MDA MK1
Trev, it looks good, I notice the walls are painted white too and that makes a difference. If you are working over the winter, then you might need a heater too!
chris h is offline   Reply With Quote
Old 9th December 2009, 10:02 AM   #25
trevorsummers
9 Tenths
GT40: Tornado TS40
Yeah I painted the walls first to brighten up the garage as it was looking very dull. I was going to paint the floor a light grey but wanted to avoid any problems with the paint lifting etc so decided to go for the rubber floor.
Day 3 – The Garage: Design, Prepping & Painting
So far the garage has been quite warm. I was expecting it to be much colder in there but its been fine. Ill probably get a heater in January when we normally get the really cold weather
Trev
----Trev----
www.gt40builder.com
Old 9th December 2009, 12:28 PM   #26
saxoncross's Avatar
saxoncross
8 Tenths
GT40: Tornado
Good luck with your build
You need to start thinking about shelving/racking. It's amazing how much space a disassembled car (even if you don't have all the parts yet) takes up!
Andy
saxoncross is offline   Reply With Quote
Old 9th December 2009, 12:54 PM   #27
trevorsummers
9 Tenths
GT40: Tornado TS40
Andy
Yeah space is going to be a bit tight in the garage. I am not taking delivery of the body to start with which should help but no doubt a few shelves will be required.
----Trev----
www.gt40builder.com
Old 9th December 2009, 02:12 PM   #28
Frank Beuker's Avatar
Frank Beuker
6 Tenths
Netherlands
GT40: kva
Trev that's a neat looking garage
Good luck with your build and keep us posted
frank
cleaning up the mess the preowners
You're never to old to start doing what you realy like doing
Frank Beuker is offline   Reply With Quote
Forum Jump
Similar Threads
New garage Fatal Attraction All GT40 79 20th October 2009 11:25 AM
Garage Flooring - which design? trevorsummers The Paddock 7 9th September 2009 11:38 AM
Garage Flooring Ron Earp The Paddock 9 5th July 2008 04:42 AM
These would all fit in my garage. PDub The Paddock 14 30th March 2005 12:47 AM
Garage Flooring Ron Earp All GT40 77 4th April 2004 08:28 PM
