| Notices | Hi member,
Enjoy the forum!
| | CAV GT40 Talk CAV GT40 discussion sponsored by VIP Classics. |
09-08-07, 10:49 AM
#1 (permalink)
| | chuck 1 7 Tenths
Rep Power: 11  | weber install finally got around to starting this project, I will keep you informed of the progress, so far much easier than my 427so weber install.
__________________ chuck smith
CAV MONO GT40-302
SPF Daytona Coupe- Roush 427r
Kirkham 427 cobra- 427so |
09-08-07, 10:50 AM
#2 (permalink)
| | chuck 1 7 Tenths
Rep Power: 11  | Re: weber install
CAV MONO GT40-302
09-08-07, 11:05 AM
#3 (permalink)
| | 2124 5 Tenths
Join Date: Jul 2004 Location: Rescue, CA GT40: Rescue, CA
Rep Power: 10  | Re: weber install Looking good!
I look forwad to the photodocumentary.
__________________ CAV #80, 331 Keith Craft, RBT Swift DB5 |
09-08-07, 04:31 PM
#4 (permalink)
| | chuck 1 7 Tenths
CAV MONO GT40-302
09-08-07, 04:35 PM
#5 (permalink)
| | chuck 1 7 Tenths
Rep Power: 11  | Re: weber install do any of you guys have the part numbers for a center bellcrank type throttle linkage, My Kirkham has one but the webers are mounted fuel inlet inward and the CAV faces them outward, also the 427 manifold is larger so the linkage is different. It looks like this.
CAV MONO GT40-302
09-08-07, 04:49 PM
#6 (permalink)
| | 2124 5 Tenths
Rep Power: 10  | Re: weber install How about a linkage like this one?
I have a bracket that the cable attaches to for it.
09-08-07, 05:16 PM
#7 (permalink)
| | chuck 1 7 Tenths
Rep Power: 11  | Re: weber install Pat ,I think I have that bracket.
CAV MONO GT40-302
09-09-07, 12:09 AM
#8 (permalink)
| | Randy Bronze Supporter
Rep Power: 2  | Re: weber install Chuck. Thanks for the post. Are those fuel regulators you have added? I am wondering were the CAV units set to high PSI for webers?
Randy |
09-09-07, 09:38 AM
#9 (permalink)
| | chuck 1 7 Tenths
Rep Power: 11  | Re: weber install Randy, they are the standard units and I assume are set at 5-6 psi now ,so they will need to be changed. I have no idea how to lower them, maybe someone here does.
CAV MONO GT40-302
09-09-07, 09:53 AM
#10 (permalink)
| | 2124 5 Tenths
Rep Power: 10  | Re: weber install Install a fuel pressure regulator.
09-09-07, 10:17 AM
#11 (permalink)
| | chuck 1 7 Tenths
Rep Power: 11  | Re: weber install Pat, I think those are regulators mounted on the bulkhead, I do not know haw to adjust them down however.
CAV MONO GT40-302
09-09-07, 11:56 AM
#12 (permalink)
| | Neal 8 Tenths
Join Date: Sep 2001 Location: Seattle, WA, US GT40: GT40 NZ
Rep Power: 15  | Re: weber install Chuck,
Holley and Aeromotive make low pressure, 2-3 psi, regulators.
__________________ GT40 NZ - 347 / Webers / Red and White - My build site
FFR Roadster #4867 408 / TKO / 3-Link |
09-09-07, 07:51 PM
#13 (permalink)
| | 2124 5 Tenths
Rep Power: 10  | Re: weber install Chuck -
I think those are one way valves so you don't keep swapping fuel from each tank.
I could be wrong.
But I don't think so!
09-09-07, 07:53 PM
#14 (permalink)
Rep Power: 2  | Re: weber install Chuck, I bet the CAV regs. are adjustable, I just removed the acorn nut from top of regs. and there is a adjustment screw. I have CAV 134 and am about to do what you are doing. Try backing screw off,these are diaphragm style regs,but will they go low enough?
randy |
09-09-07, 08:40 PM
#15 (permalink)
| | chuck 1 7 Tenths
Rep Power: 11  | Re: weber install this seems to indicate the regulator can be lowered plenty Weber Parts
CAV MONO GT40-302
09-12-07, 09:37 AM
#16 (permalink)
| | JCoop 2 Tenths
Join Date: Jan 2006 Location: New York, USA GT40: CAVMONO29
Rep Power: 5  | Re: weber install Quote:
Originally Posted by Randy Chuck, I bet the CAV regs. are adjustable, I just removed the acorn nut from top of regs. and there is a adjustment screw. I have CAV 134 and am about to do what you are doing. Try backing screw off,these are diaphragm style regs,but will they go low enough?
randy | The CAV regs I have on #29 are adjustable to 3.5 PSI, no lower. I've installed inline gauges on both sides before feeding the 48IDAs. Back out the acorn locknuts and turn the adjuster nut. They were originally set to 5 PSI to feed the Holley but the new plumbing for the Webers leaked at that setting.
__________________ Ray
GT40 CAV Mono29
Cobra SPF #1052
MB CL600 V12
'67 Austin Mini Cooper S
MB E350 4matic (commuter)
Looking for a Cessna Aerobat |
09-12-07, 07:24 PM
#17 (permalink)
Rep Power: 2  | Re: weber install Ray ,how do the webers like 3.5 psi.? I would think it would work.
Randy |
09-12-07, 09:49 PM
#18 (permalink)
| | Dlampe Silver Supporter
Join Date: Jun 2006 Location: Centralia IL GT40: RCR GT 40
Rep Power: 9  | Re: weber install I really don't think it is going to work. If you could have 2.5 or 3.5, you would be much better with 2.5. I think your float needle and seat with leak at 3.5. |
09-12-07, 10:23 PM
#20 (permalink)
| | chuck 1 7 Tenths
Rep Power: 11  | Re: weber install thanks Rick, I found them and talked to the guy today and he set me up with the needed stuff.
CAV MONO GT40-302
