Old 09-05-06, 06:57 AM   #81 (permalink)
albanygt40's Avatar
albanygt40
3 Tenths
GT40: Albany west Aus
Rep Power: 6 albanygt40 is a jewel in the rough
Smile
I thought that setting up the Acc pedal would be easy but it turned
out a bit tricky. Fitted a universal cable kit which all worked out well in the end. I've got another DRB GT40 to work on for a friend, He's bolting it togethor, I'm basically doing the fab work. Hopefully my rad will turn up
soon. Getting hold of front brake discs at a reasonable price is proving
to be a challenge.
ID:	15190  Click image for larger version
ID:	15191  Click image for larger version
ID:	15192  Click image for larger version
What! another DRB GT40...
albanygt40 is offline
Old 09-10-06, 05:54 AM   #82 (permalink)
albanygt40's Avatar
albanygt40
3 Tenths
Smile
couple of more pics
ID:	15288  Click image for larger version
Old 09-26-06, 03:53 AM   #83 (permalink)
albanygt40's Avatar
albanygt40
3 Tenths
Talking Re: Chassis #64 due in July
Hey All
fitted radiator and electric water pump on the weekend.
Also plumbed rear brake and clutch bundy lines. The rad is
an Aussie desert Cooler job. Fitted thermo fan in front of
the radiator.
Old 09-30-06, 10:00 PM   #84 (permalink)
albanygt40's Avatar
albanygt40
3 Tenths
Not much progress happening as injured my finger with an exploding
grinding disc. My young bloke was kind enough to slide my front
rotors on.
Old 10-01-06, 02:07 AM   #85 (permalink)
JackW's Avatar
JackW
Magnificent Bastard
GT40: Melbourne, Aust
Rep Power: 7 JackW is a splendid one to behold
Hi DAve
Just a quick and easy question. Have you rdered the body with the extra wide gulf wheel flared arches or the regular? I can't really tell from the pictures.
JAck
Keeping the dream alive!
Original Mach 2 - From Xbox Forza
JackW is offline
Old 10-01-06, 02:25 AM   #86 (permalink)
albanygt40's Avatar
albanygt40
3 Tenths
Smile Re: Chassis #64 due in July
Hey Jack
I ordered the standard body. The biggest factor in my decision was that
I already had my wheels before I ordered the car as they were going on my
Cobra. They're only 10inchs wide and would look like cheese cutters under
Gulf flares.
Old 10-14-06, 02:16 AM   #87 (permalink)
JackW's Avatar
JackW
Magnificent Bastard
Very interesting Dave. Tell me, do you think you could get 10.5 in, or 11 inch wide wheels into the rear arches of the regular body DRB? I have an odd fascination on this subject, particularly in relation to DRB's as the extra wide body is well known to be able to handle the 12in wide wheels, but the regular body, to my untrained eye anyway, doesn't look that much less wide (well compared to an RF anyway, which is all I have alternativey seen and can compare too).
Jack
JackW is offline
Old 10-14-06, 02:51 AM   #88 (permalink)
albanygt40's Avatar
albanygt40
3 Tenths
Hey Jack
I think you could just fit 10.5's but don't hold me to that. The 10's
look good under the rear standard arches as that is what Dennis Bedford
designed the car for. You can tune the look of the rear by changing tyres
to suit the look you want. My Rims came with 295/50/16 TA's and they looked real fat in the arch (can I say that?) but I wanted to run race rubber and had to settle for 255's as that is what is available.
Old 10-14-06, 05:20 AM   #89 (permalink)
albanygt40's Avatar
albanygt40
3 Tenths
Fitted header tank and Overflow tanks today.
With all the other cooling system components fitted now I just need
to connect up hoses and that should be the cooling system finished.
Old 10-16-06, 09:16 AM   #90 (permalink)
Pete's Avatar
Pete
GT40: GT40 Australia.
Rep Power: 40 Pete has a brilliant futurePete has a brilliant futurePete has a brilliant future
Hi Dave, do you work 24 hours a day on that thing? It must play havoc with your sex life?
Great progress and really looks well engineered. I have a suggestion for a shake down run once you have it registered. A run across the Nullabor to Brisvegas and the famous sausage sizzle at DRB.
Cheers, Pete.
DRB chassis 48.
Queensland Australia.
Pete is offline
Old 10-19-06, 09:09 AM   #91 (permalink)
albanygt40's Avatar
albanygt40
3 Tenths
Pete working on the GT40 is sex??? Hoping to drive to the Cobra Nationals
and say G'day to everyone in NSW, then up to QLD for a BBQ , Hopefully
I can con a few others to drive their GT40's aswell.
Sealed up the trans tunnel pipes with Aeroflex insulation hose today
and mounted trans tunnel for the final time, thanks to Flatchat for a lovely
gearstick knob. Gearshift feels good and positive (shifter is from a Corolla).
ID:	15895  Click image for larger version
ID:	15896  Click image for larger version
ID:	15897  Click image for larger version
ID:	15898  Click image for larger version
Old 11-05-06, 02:14 AM   #92 (permalink)
albanygt40's Avatar
albanygt40
3 Tenths
After spending a few days sorting out my clutch problems and
thanks again to Jim C for his help.I have fitted seat belts, Brake and Clutch
reseviors and plumbed the electric water pump in.
ID:	16223  Click image for larger version
ID:	16224  Click image for larger version
Old 11-10-06, 06:05 AM   #93 (permalink)
albanygt40's Avatar
albanygt40
3 Tenths
I think it's a milestone when you fit the Tail lights. DRB's door handles
fit perfectly in the door recesses. Just need to source some headlights now.
ID:	16281  Click image for larger version
Old 11-12-06, 10:35 PM   #94 (permalink)
ckouba's Avatar
ckouba
5 Tenths
GT40: RCR40-31
Looks like it's time for a new avatar...
Looking great Dave.
Chris
RCR40 #31 - SBF, ZF, 15" BRM, LHD, Center shift
10 Jan 07 - Picked it up
25 Feb 07 - Body mounted
15 Mar 07 - Motor/trans installed for the first time
30 Mar 07 - Wide track rear suspension installed
05 May 07 - Cage built and installed
June 07 - Sept 07: Sabbatical!!
Oct 07 - today: Never-ending body prep
My Build Thread
ckouba is offline
Old 11-19-06, 08:10 AM   #95 (permalink)
albanygt40's Avatar
albanygt40
3 Tenths
Thanks Chris
Spending heaps of time plumbing stuff which seems to take forever.
But I'm slowly ticking off the boxes. Finished the cooling system, just need
to add water.
Old 12-02-06, 07:01 AM   #96 (permalink)
albanygt40's Avatar
albanygt40
3 Tenths
Fitted vent and demist system, hope I don't have to end up fitting A/c.
Finished my Registration Exhaust system which is hopefully as quiet and
restrictive as it looks. What a waist of money and time.
ID:	16623  Click image for larger version
ID:	16624  Click image for larger version
ID:	16625  Click image for larger version
Old 12-02-06, 09:09 AM   #97 (permalink)
albanygt40's Avatar
albanygt40
3 Tenths
I think this is my final colour choice, The blue is a ford colour called
Bionic, I'm planning to add two wide white stripes and side white stripes.
Old 12-03-06, 03:21 AM
