LinkBack (7) Thread Tools Display Modes
Old 12-03-06, 01:36 PM   #101 (permalink)
Malcolm's Avatar
Malcolm
Gold Supporter
GT40: GTD
Re: Build Diary - RCR Lola T70 Spider
If you fit a blower don't forget to fit a toilet roll holder to the dashboard! We'll need it!
Malcolm
GTD40, Mazda MAX5 MX5, Porsche 996 C4S
Lotus 51c for sale
Malcolm is offline
Old 12-03-06, 04:37 PM   #102 (permalink)
StanJ
Sponsoring Vendor
Rep Power: 4 StanJ is on a distinguished road
From these pictures, I can’t quite get a perspective of where the deck height of the rear bodywork is going to end up, but I’m assuming that you’ll want to get the inlet up into “clean” air. How about something like this combination, Ron?
K&N now makes filters for these scoops, which makes them a lot more practical for endurance-type applications.
Harwood, CSR, and K&N products areavailable from many vendors on the net, and I'm sure that you can find other similar products as well
StanJ is offline
Old 12-03-06, 05:36 PM   #103 (permalink)
Ron Earp's Avatar
Site Administrator
Hey Stan,
I like that, I'll look for those. I assume some sort of panel filter fits into the rectangle area?
I think the carb top is just going to come clear from the body work by about two inches. Now, there is enough room for a big round filter for sure, but having a little attitude and some fresh air would be good!
Found this one on ebay, pretty sweet!
Ron
Ron Earp is offline
Old 12-03-06, 07:20 PM   #104 (permalink)
jac mac's Avatar
jac mac
New Zealand
Rep Power: 21 jac mac has much to be proud ofjac mac has much to be proud of
Thumbs down Re: Build Diary - RCR Lola T70 Spider
Originally Posted by Ron Earp
Hey Stan,
Ron
Now I know why Malcolm wanted the Toilet Roll Holder!! Might need a PUKE can for the drivers as well if they have to look at that edifice in the mirrors all the time.
Jac Mac
jac mac is offline
Old 12-07-06, 09:29 AM   #105 (permalink)
Ron Earp's Avatar
Site Administrator
Link back to carb thread, had two PM's wondering where it is. It is in the Engine/Induction section.
http://www.gt40s.com/forum/tech-engi...ola-motor.html
Ron Earp is offline
Old 12-07-06, 09:54 AM   #106 (permalink)
llarsen's Avatar
llarsen
GT40: Sabre
Ron,
Mr Gasket has some nice street scoop stuff. Found it on Jegs.
Click Image
Lynn
Sabre GT40/5L EFI/G50/50
Always verify parts or products discussed for your own use.
llarsen is offline
Old 12-07-06, 10:01 AM   #107 (permalink)
llarsen's Avatar
llarsen
GT40: Sabre
Ron,
Here is a link to what Summit has: Mr Gasket and a Summit branded one.
Click Image
Lynn
llarsen is offline
Old 12-07-06, 04:05 PM   #108 (permalink)
gt40fran's Avatar
gt40fran
Sponsoring Vendor
GT40: Michigan,USA
This kind of scoop may be more use......especially with your mighty engine!!
RCR-40..Mk1, 2 and Mk4
RCR-70 Mk3b
RCR-70 Spider
RCR-P4
Superlite Coupe
RCR917
XJ13 for SCF
www.RACECARREPLICAS.COM
www.superlitecars.com
gt40fran is offline
Old 12-07-06, 06:47 PM   #109 (permalink)
Ron Earp's Avatar
Site Administrator
Now that is some excellent factory support!
Ron Earp is offline
Old 12-08-06, 12:47 AM   #110 (permalink)
StanJ
Sponsoring Vendor
Hmmmm.....
The guys at RCR aren't implying that your engine might actually take a dump, are they Ron?
StanJ is offline
Old 12-08-06, 07:29 AM   #111 (permalink)
Ron Earp's Avatar
Site Administrator
Hey Stan, no, Fran and I discuss the car all the time I'm just poking fun. He's implying we might need to sweep up the gear box!
The motor was built a few years back before I started wheel to wheel racing, and then rebuilt again to sustain higher RPM (gridle, valve train, soller roller, etc.). In either case, it probably is going to stress the gearbox fairly badly. I think the solution would be a 930 box, or maybe a ZF, but since I already had the Audi Getrag box we figured we'll try it and collect some real-world data on those boxes and if they are suitable or not.
Ron
Ron Earp is offline
Old 12-08-06, 08:23 AM   #112 (permalink)
gt40fran's Avatar
gt40fran
Sponsoring Vendor
GT40: Michigan,USA
Actually thats a poop scoop.....
I figured someone may need to clean up a little poop with the 500plus HP drivtrain.......but Rons expanation does have some validity....
RCR-70 Mk3b
RCR-70 Spider
RCR-P4
Superlite Coupe
RCR917
XJ13 for SCF
gt40fran is offline
Old 12-08-06, 08:46 AM   #113 (permalink)
Ron Earp's Avatar
Site Administrator
Ah, I missed that poop scoop explination. No matter, I wear Depends under my fire suit!
I'm thinking about 300hp would be a lot better in this car, both for car and driver.
R
Ron Earp is offline
Old 12-08-06, 10:49 AM   #114 (permalink)
StanJ
Sponsoring Vendor
500 horsepower, eh? Well maybe if you pull a plug wire...
StanJ is offline
Old 12-27-06, 12:03 PM   #115 (permalink)
Ron Earp's Avatar
Site Administrator
A little progress over the holidays with trial fitting of the deck and seeing how it sits in there. It is not centered over the wheels exactly, but it fits well with a good amount of room up front. In fact, one would have room for a magneto in there if one wanted..... Anyhow, looks pretty good. Other time has been on the Jensen over there in the back ground to make a early Jan. test date. It is nice only having the JH and the Lola to worry about, the Miata is on the trailer to leave today!!!
ID:	16956   Click image for larger version
Ron Earp is offline
Old 12-27-06, 05:03 PM   #116 (permalink)
Ron Earp's Avatar
Site Administrator
And one more.....
Ron Earp is offline
Old 12-27-06, 10:53 PM   #117 (permalink)
StanJ
Sponsoring Vendor
Hey Ron, do you have any pics that would be representative of how you want the rear deck area to look when you're done? I can envision how a scoop similar to the one I posted a photo of earlier might work out...placing the inlet in "clean" air just above the safety loop, but you'd probably want to "fair in" the gap between the base pan and the deck proper with some sort of flexible material. I can see in my minds eye how it would look, but it might not be visually acceptable for a Lola "purist".
StanJ is offline
Old 12-28-06, 10:37 AM   #118 (permalink)
OhioMark
Rep Power: 3 OhioMark is on a distinguished road
Ron:
Do you think you'll ever use velocity stacks on the Lola? They'd
look cool since the deck is low etc...Thanks!
Mark
OhioMark is offline
Old 12-29-06, 11:17 AM   #119 (permalink)
Johan's Avatar
7 Tenths
GT40: USA
