Old 04-30-07, 11:22 PM   #121 (permalink)
ckouba's Avatar
ckouba
5 Tenths
GT40: RCR40-31
Re: Jonathans RCR 40 Build
Jonathan-
Could you post a few more details or pics regarding the steering column and turn signal switch. I have been pondering this exact concept and would appreciate the info.
Looking great.
Chris
RCR40 #31 - SBF, ZF, 15" BRM, LHD, Center shift
10 Jan 07 - Picked it up
25 Feb 07 - Body mounted
15 Mar 07 - Motor/trans installed for the first time
30 Mar 07 - Wide track rear suspension installed
05 May 07 - Cage built and installed
June 07 - Sept 07: Sabbatical!!
Oct 07 - today: Never-ending body prep
My Build Thread
ckouba is offline
Old 05-01-07, 08:00 AM   #122 (permalink)
jonathans's Avatar
jonathans
Silver Supporter
GT40: RCR
Rep Power: 7 jonathans is just really nice
It is pretty simple. It is a 6" piece of 1.5" round stock that I welded a bolt to. I welded a piece of angle iron to the bracket that the pillow block is on to bolt it to. I slotted the angle iron to allow adjustment. I'll post some pictures tonight.
RCR GT40
Build Page: https://home.comcast.net/~jonathanstrain/
jonathans is offline
Old 05-02-07, 10:02 PM   #123 (permalink)
jonathans's Avatar
jonathans
Silver Supporter
GT40: RCR
Here are some shots of the column. As I said, it is pretty simple. I am a firm believer in the KISS principle:
ID:	19634  Click image for larger version
RCR GT40
Old 05-03-07, 02:01 PM   #124 (permalink)
ckouba's Avatar
ckouba
5 Tenths
GT40: RCR40-31
Thanks Jonathan. Looks like you've thought this one through for me. Much appreciated.
Is that one of the VW Beetle switches from JCW? Do you have the p/n?
Looks great!
Chris
My Build Thread
ckouba is offline
Old 05-03-07, 02:25 PM   #125 (permalink)
jonathans's Avatar
jonathans
Silver Supporter
GT40: RCR
I got it from Finsh Line:
Finish Line Accessories
I used the same switch on my Cobra.
RCR GT40
Old 05-09-07, 11:42 AM   #126 (permalink)
jonathans's Avatar
jonathans
Silver Supporter
GT40: RCR
These shots are for Bill. He was looking for more information on the alterations to the dash to make a '65 Mustang dash vent work. The first shot shows the revisions to the opening. The areas boxed in red were filled. The areas boxed in yellow were relieved using a router. Some of the areas that were relieved needed to be built up on the back side prior to relieving them to avoid going all the way through the dash:
RCR GT40
Old 05-09-07, 11:43 AM   #127 (permalink)
jonathans's Avatar
jonathans
Silver Supporter
GT40: RCR
I also built up two tabs both from the front and behind to give the mounting screws something to bit into. I built these up using fiberglass and resin to give it strength. These are circled in black:
RCR GT40
Old 05-09-07, 11:50 AM   #128 (permalink)
jonathans's Avatar
jonathans
Silver Supporter
GT40: RCR
And last i needed to cut two slots for tabs on the Mustang vent to lock into. These allow you to attach the vent with just two screws on the front. These are circled in yellow below:
RCR GT40
Old 05-09-07, 12:06 PM   #129 (permalink)
Bill D's Avatar
Bill D
I Have No Life
Thanks a bunch Jonathan. And I got your PM reply. Thanks again
I will print these pictures and send them to the body man along with the grille.
Bill D
RCR GT40 Mk1 Gulf
Bill D is offline
Old 05-09-07, 01:23 PM   #130 (permalink)
jonathans's Avatar
jonathans
Silver Supporter
GT40: RCR
It should be pretty easy for him to see what I have done. Everything is a little clearer in these shots with everything one color again.
RCR GT40
Old 05-14-07, 09:50 PM   #131 (permalink)
jonathans's Avatar
jonathans
Silver Supporter
GT40: RCR
I finally have all my accessories so I could fabricate my brackets. I went with Explorer front trim so all the brackets had to be made from scratch. Everything is tight. The AC compressor would only fit on the bottom passenger side (LH Drive) and the alternator had to go on the driver side top. I started with a 93 Mustang alternator but it would not fit where I wanted it. I found a GM truck alternator fit fine. Here are some pictures:
ID:	19931  Click image for larger version
ID:	19932  Click image for larger version
ID:	19933  Click image for larger version
RCR GT40
Old 05-14-07, 10:18 PM   #132 (permalink)
Bill Haralambakis's Avatar
Bill Haralambakis
Old Hand
GT40: RF
Rep Power: 14 Bill Haralambakis has a spectacular aura about
Jonathon
It's probably only the perspective of the last photo, however it looks like the alternator pulley is not parallel with the crank pulley. Would pay to check it, although I'm sure you have already done this.
Great looking motor though and an awesome build overall!
Bill H
RF GT40
Chassis 061
On the road baby!
Bill Haralambakis is offline
Old 05-14-07, 10:32 PM   #133 (permalink)
Big-Foot's Avatar
Big-Foot
Gold Supporter
GT40: Replica
Rep Power: 20 Big-Foot has a brilliant futureBig-Foot has a brilliant futureBig-Foot has a brilliant future
Very nice Jonathan!!!
Are you trying for the BUMPless Bulkhead? I'd really like to find out what the right combination is to get there.. I'm not crazy about the electric waterpump route either..
Regards - Randy
Big-Foot is offline
Old 05-14-07, 10:51 PM   #134 (permalink)
jonathans's Avatar
jonathans
Silver Supporter
GT40: RCR
I have found you cannot "eyeball" pulley alignment. It takes a straight edge. The alternator is pretty close but not perfect. It is a lot closer than that photo looks though. It will require a little more tweeking.
RCR GT40
Old 05-14-07, 11:19 PM   #135 (permalink)
jonathans's Avatar
jonathans
Silver Supporter
GT40: RCR
I should be putting the motor in later this week. I will let you know if it is bumpless. The combination is pretty simple. It is an Explorer front cover and water pump. This requires the use of an Explorer harmonic balancer and pump pulley since there are not a lot of aftermarket parts for this combination. The pump pulley is only $12 from ford. The harmonic balancer is pretty easy to get as a cast off from a crate motor. I think I paid $15 for the balancer.
This is only about a 1/4 inch shorter than 95 Mustang parts which has a lot more aftermarked support.
RCR GT40
Old 05-15-07, 09:02 AM   #136 (permalink)
Dalton
4 Tenths
Rep Power: 8 Dalton is just really nice
Fantastic build. I see you have the hammer ready for those final tweaks in fitting the engine.
Dalton
Dalton is offline
Old 08-14-07, 10:19 PM   #137 (permalink)
jonathans's Avatar
jonathans
Silver Supporter
GT40: RCR
I have not updated my site for some time. I have actually had quite a bit of progress but I have not taken the time to update my site. I have the motor back in for mock up again and I have painted all the links in the rear suspension to match the body color:
RCR GT40
Old 08-14-07, 10:21 PM   #138 (permalink)
jonathans's Avatar
jonathans
Silver Supporter
GT40: RCR
I have also mocked up most of the AC system. Here are some photos:
ID:	22816  Click image for larger version
ID:	22817  Click image for larger version
RCR GT40
Digg this Post!Add Post to del.icio.usBookmark Post in Technorati
