Old 04-07-04, 11:14 PM   #1 (permalink)
patbarry's Avatar
Gold Supporter
GT40: Houston, Texas
Jacking Front End
I have been struggling with jacking the front end once the front clip is mounted. Many thanks go to Dave Morton for his sending pictures of how he solved the problem. (Yes, I have permission to post!)
Thanks again Dave
Name:	35404-Picture 038 Small.jpg
patbarry is offline
Old 04-07-04, 11:16 PM   #2 (permalink)
patbarry's Avatar
Gold Supporter
Re: Jacking Front End
And the modified jack...
Name:	35405-Jack 002 Small.JPG
patbarry is offline
Old 04-07-04, 11:17 PM   #3 (permalink)
patbarry's Avatar
Gold Supporter
Last one. Well done Dave!
Name:	35406-Jack 005 Small.JPG
patbarry is offline
Old 04-08-04, 01:39 AM   #4 (permalink)
New Zealand
GT40: New Zealand
Rep Power: 8 brianstewart will become famous soon enough
Brilliantly simple!
brianstewart is offline
Old 04-08-04, 01:58 AM   #5 (permalink)
Hershal Byrd
GT40: RF
Maybe this ain't a big deal but I push my GT up onto 2X10's
then lift it with the jack. Works good for me. There ain't no jack that I know of that is built low enough to lift the GT without it being lifted at least 2 inches first,
Hershal Byrd is offline
Old 04-08-04, 02:44 AM   #6 (permalink)
BenL's Avatar
BenL
6 Tenths
[ QUOTE ]
[/ QUOTE ]
I don't know of a hydraulic floor jack that low, but there are non-hydraulic jacks that are low enough.
From the Pegasus catalog (http://www.pegasusautoracing.com/):
Quick-Lift Jack
This well *made jack is low enough to fit beneath most formula cars and sports racers. It features a nine inch lift height, thirty-*one inch reach, rugged all steel construction, (no fragile castings to break), five wheels, and a detachable T-*shaped handle. Maximum weight approximately 1000 lbs.
Quick*Lift Jack . . . . . . . . . . . . . . . . . . . . . . . . . . . Part No. 3170 . . . . $179.99
I have one. I can use it to lift the front of the car, but I don't weigh enough to lift the rear.
If you want to see it in the catalog, view page 91, or click on "Order On-line" and enter the part number (3170).
BenL is offline
Old 04-08-04, 04:07 AM   #7 (permalink)
David Morton's Avatar
David Morton
GT40: The Jewel on th
Rep Power: 36 David Morton has a brilliant futureDavid Morton has a brilliant futureDavid Morton has a brilliant future
This Weber jack in the pictures above is the lowest profile
jack that I can find in the UK. I will measure it today and post the height when I get back from work.
Dave
David Morton is online now
Old 04-08-04, 07:33 AM   #8 (permalink)
Fatal Attraction's Avatar
Fatal Attraction
GT40: Ex-DRB #35
Rep Power: 23 Fatal Attraction has a spectacular aura about
For those of us without external lifting lugs.......
Has anybody considered using a modified pallet jack?
Most have less than 4" height(lowered), long arms (two lifting points), hold a ton or more, could lift either end of a 40 easily, and are relatively cheap.(eg. ebay-$200)
They have only two drawbacks that I can see.
1. Lifting height is limited to about 8"(could be raised
with 2x4 blocks or rubber pads). Getting tires off the
ground or the car onto jackstands, might be a problem.
2. It's bound to be one of those tools that is always in
the way until you need it!
BUT, just think about how handy it would be when the next heavy load arrives at your shop door(engine, gearbox, beer refrigerator, etc.)! Try moving one of them around the garage with a floor jack! [img]/ubbthreads/images/graemlins/shocked.gif[/img]
You could lift and move the entire car around the garage! [img]/ubbthreads/images/graemlins/cool.gif[/img]
Any thoughts?
Fatal Attraction is offline
Old 04-08-04, 09:01 AM   #9 (permalink)
CCX33911
GT40: Virginia
There was a long very low hyd. jack discussed on here before. Also I have the low cost Harbor Freight Alum jack and with 4.375 front ride height I can go in front of the front tire and lift off of the suspension pickup without problem.
CCX33911 is offline
Old 04-08-04, 09:03 AM   #10 (permalink)
Fatal Attraction
GT40: Ex-DRB #35
There are scissor lift style pallet jacks available, which
would work perfectly (2 7/8"-32 1/2" range), if not for the
$500+ price tag! [img]/ubbthreads/images/graemlins/frown.gif[/img]
Gary,
That's exactly what I do, and have no problem, but it
would be great to lift the front or rear end, as a whole.
Old 04-08-04, 09:08 AM   #11 (permalink)
IanAnderson's Avatar
IanAnderson
Gold Supporter
GT40: Dax 40 Mk1 (Rov
Rep Power: 18 IanAnderson is a jewel in the rough
As a different option
A while ago in Africa a device call "Air Jack" No not the ones used in a pit lane for quick tyre change but an inflatable sack!
This is the type of thing http://www.afil.co.uk/airjack/index.shtml
The one I saw in use rolled up really small - like a kids backpack, was unrolled and slid under the car / trailer or whatever and then the tube attached to the car exchust pipe.
Within a minute the car wheel was off the ground.The engine could then be turned off and within reason the bag retained the pressure. Release a valve and the whole thing deflated ready for rolling again.
Being "soft" it did not put undue pressure on any suspension parts etc.
Also as a thought your ride height is set at 4.5 inches, what happens when you get a puncture and that decreases to 1.5 inches? Even at that clearance the bag could be slid / worked under the car.
Lateral thinking?
IanAnderson is offline
Old 04-08-04, 12:10 PM   #12 (permalink)
Fatal Attraction
GT40: Ex-DRB #35
Ian,
Good point about the 1 1/2" clearance with a flat tire!
I seriously doubt that anybody builds a jack that short!
I carry two cans of Fix-a-Flat in the car at all times,
should that ever happen.
Old 04-08-04, 12:24 PM   #13 (permalink)
IanAnderson
Gold Supporter
What happens in a "Blow Out" situation? The can's don't work very well when the tyre is in shreads along the road!
Even the AA / Recovery truck will not be able to get a jack under the stricken car!
Next problem would be when he tries to attach the winch and tow it on to the flatbed and the nose clip disintegrates on the ramps
Old 04-08-04, 02:05 PM   #14 (permalink)
patbarry's Avatar
Gold Supporter
But none of them looks as cool as Dave's, and if ain't cool, it ain't for me. But then my wife says I'm a huge dork so what do I know.
patbarry is offline
Old 04-08-04, 02:11 PM   #15 (permalink)
David Morton
The wheels on the Weber jack are the limiting height at 3" and the centre 'spinner' sits below that with the rubber disc removed. With the Rubber disc it will measure 3.4".
I am not advertising but if anybody is interested send me an email and I can give you the companies details (in Essex, UK).
We also use an air bag jack on our F1 trailer which can lift a Mercedes Sprinter at 3.5 tonnes. I think about 1.5 inches is the minimum height to slide the bag underneath.
Dave
Happy Easter everybody.... [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img]
Old 04-08-04, 03:58 PM   #16 (permalink)
GT40: Los Angeles
Rep Power: 5 MBelcher is on a distinguished road
Tri-C engineering has a "Flat Jack," which in the lowered position is only 1.5 inches high. Tri-C's e-mail is hotrods@tri-cengineering.com or they can be reached at [661] 295-1550.
MBelcher is offline
Old 04-08-04, 04:08 PM   #17 (permalink)
David Morton
PS I use GoJacks as well which are foot operated to raise any or all four corners and I can spin the car around unaided and park it right against a wall if needed. And - it lives in its own cocoon as well with carbon filtered fresh air with gel battery conditioning. It's a bit pampered in a way but since I bought her indoors a diamond and sent her and 2 offspring to NY shopping, I can get away with murder - almost...
Dave M + old forrester (a few now)
Old 04-08-04, 07:15 PM   #18 (permalink)
Fatal Attraction
GT40: Ex-DRB #35
Ian,
In a blowout situation, you're pretty well screwed, no matter how you look at it!
I guess that you could try lifting the entire front end from the opposite side? Don't know if that would work, but it'd be worth a try, before trashing the front clip while dragging the car up onto a rollback.
Mike,
Does Tri-C Engineering have a website? I'd love to see a photo of that 1 1/2" high jack. Any idea on how much $$$?
Old 04-08-04, 08:13 PM   #19 (permalink)
David Morton
The hooks on the front chassis and the lifting bar with the jack are capable of lifting the car with rims only. The
trick is to be able to carry a trolley jack on board as well !!! no - taking the p-ss.. I will work on another way
of lifting the hooks with a light weight jack and get back again. It would be no big deal to carry the lifting bar somewhere down the back end. I'll try and think something out in the next week or so then come back.
Dave M
Old 04-08-04, 08:35 PM   #20 (permalink)
wbmusarra's Avatar
wbmusarra
GT40: DRB#5
If you shred a tire
