Old 01-14-08, 09:50 AM   #1 (permalink)
Brian Coombs
GT40: kva/rml
Rep Power: 2 Brian Coombs is on a distinguished road
Electric handbrake
Is anyone using the electric handbrake module form a Ford Focus C max on their GT40? it seems a very easy way not to route the cables through the engine bay? The handbrake would be operated by a switch on the dash? I know a super car manufacturer here in the UK is using it?
BC
Brian Coombs is offline
Old 01-14-08, 04:55 PM   #2 (permalink)
john_douglass's Avatar
john_douglass
GT40: KVA
Rep Power: 4 john_douglass is on a distinguished road
Cool Re: Electric handbrake
BC
BC,
Could you give me some more details and pictures if possible. Will the handbrake calipers mount on Corvette rotors?
John
john_douglass is offline
Old 01-15-08, 10:18 AM   #3 (permalink)
Brian Coombs
GT40: kva/rml
sorry John,
I don't have any pictures at the moment, but it is small box which has the two handbrake cables coming out of it, and I guess has a motor with a reduction gearbox inside which applies the tension to the cables?
This motor is controlled by an electrical switch, which can be placed anywhere?
Old 01-15-08, 10:33 AM   #4 (permalink)
brettmcc's Avatar
brettmcc
GT40: RSGTD
Rep Power: 19 brettmcc is a name known to all
Brian,
I would also have a look at the S-Type as well.
Brett
brettmcc is offline
Old 01-15-08, 10:53 AM   #5 (permalink)
simonjrwinter's Avatar
simonjrwinter
serial GT40 owner
GT40: GTD
Rep Power: 24 simonjrwinter has a spectacular aura about
Or some Renaults
Simon
GTD with Southern GT rear end. Lowered engine and gearbox. 302, R21T gearbox with LSD.
simonjrwinter is offline
Old 01-15-08, 03:30 PM   #6 (permalink)
GT40: Northamptonshire, UK
Rep Power: 7 Chris Notley is on a distinguished road
Hello Brian, Very long time no speak !! Since doing that particularly fast and successful JCB, what now and how is that GT40 of yours coming along ?
The electric park brake (EPB) and its various OE applications mentioned in this thread and also including VW Passat, Audi, Bugatti etc is manufactured by TRW, last I heard they produce about 1.5 million units per year so there should be a few scrapped ones out there !! It is a cable puller system and could work well on a GT40 provided you can find som place to package the unit but what is wrong with a park brake lever ? Mine gets through the MOT every year !! Be aware that the EPB unit has its own ECU so may not just be a case of a switch on the dashboard.
Chris Notley is offline
Old 01-16-08, 06:51 AM   #7 (permalink)
Brian Coombs
GT40: kva/rml
Thanks, Chris,
there is nothing wring with the normal Park brake system, but it would be one less thing to get up the tunnel between the seats, it is getting quite busy in there...
BC
Old 05-29-08, 08:38 AM   #8 (permalink)
jferraro's Avatar
jferraro
GT40: RCR40
Rep Power: 1 jferraro is on a distinguished road
Have you made any progress on the EPB? I too would like to consider one.
Jason
Build site: http://www.GT40supercharged.com
The build begins!
jferraro is offline
Old 05-29-08, 10:03 AM   #9 (permalink)
SteveBarker's Avatar
SteveBarker
Silver Supporter
GT40: MDA GT40MkII
Rep Power: 6 SteveBarker is on a distinguished road
Brian
I looked at these systems but found that if an SVA test will be taken they will not pass the 'mechanical' definition.
Although they are on new cars, the SVA definiton still has to be met, even having been passed on 'type approval'
Chances are that an MOT would not pick up on this so you would probably get away with it if you do not need the SVA.
It is a bit like the 'Hi-Spec' hydro/mechanical rear calipers that some of the SVA Vehicle inspectors rejected; I believe these have been redesigned now to apply the handbrake totaly mechanicaly.
Stephen
SteveBarker is online now
