Old 07-17-08, 10:34 AM   #1 (permalink)
PDub's Avatar
PDub
6 Tenths
GT40: Tornado
Bending Stainless Steel Pipe.
I'm looking at making new anti-roll bars for my car a little stiffer than the curent items. I've sourced some 3/4 inch stainless tube but wondering before I rent a pipe bender (Usually just used for copper pipe) if it will be possible to bend the pipes.
Has anybody used one succesfully before ?
Best regards,
P.
Black Tornado TS40 a.k.a. "Black Beauty"
SBF 306 / Edelbrock pack / R21-Turbo box / Quaife LSD
17" BRM Pindrives / Roll cage / Hi-Spec brakes
PDub is offline
Old 07-17-08, 10:44 AM   #2 (permalink)
OC_'s Avatar
OC_
Rep Power: 4 OC_ is on a distinguished road
Re: Bending Stainless Steel Pipe.
I dont think this steel is going to make for a good sway-bar. The reason is that it may not have the spring qualities that a sway/anti-roll bar needs. It all depends on the grade of steel; though, you don't see many stainless steel springs outside of very specialized applications.
Why stainless anyway? the cost for spring grade stainless is going to be huge, and probably perform less than a non-stainless bar.
bending tube on a pipe bender is going to be a problem as well. I might have this backwards, but pipe is measured on the I.D and tube is measured on the O.D. This means that the dies used for bending copper water pipe are not going to fit tubes.
You also cant go bending spring steel with out heat. This is a problem since when you heat it, the spring is going to lose its temper. Thats why a lot of sway-bars for race cars have splined ends which removable arms attach to.
OC_ is offline
Old 07-17-08, 02:41 PM   #3 (permalink)
Paul Bearman
4 Tenths
GT40: Ex GTD40 owner,
Rep Power: 11 Paul Bearman is on a distinguished road
I wouldn’t recommend using stainless steel. Use a 4140 chrome molybdenum steel or a high carbon steel such as EN24 & heat treat to achieve the required torsion.
4140 is in the range of 0.37% to 0.43% carbon but this is an American spec steel & more expensive than the EN range of steels here in the UK. EN19 is a chrome molybdenum alloy equivalent to 4140 and so is useable for the kind of hardness required.
EN24 is a high carbon, nickel, chrome, molybdenum steel alloy, very similar in composition to 4340 & has a general carbon level of 0.4% & is ideal for heat treatment & the preferred choice where applications demand high strength & resistance to shock.
0.4% carbon steels can be hardened to a maximum Rockwell "C" 44 but above 46 they become to brittle, 38 is about the minimum hardness for anti roll bars & this will give a tensile strength in the order of 170000 psi to 194000 psi. Without heat treatment it could be as low as 70000 psi. However, generally, hardening and tempering to anywhere in the range 38-44 will do the job.
Deciding on the material spec for the anti-roll bar is not the only consideration. Other important factors to consider even before parting with your hard earned cash are: centre of gravity height; roll centres; roll rates; roll couple distribution; spring rates; anti-roll bar rates; shock absorber rebound/compression rates; bushing durometer ratings; tyre size, suspension alignment specs .... the list of interacting variables is endless.
The only job of the anti-roll bar is to handle roll resistance & this can be determined through the mathematical formula:
R = [(pi)(G)(d^4)] / [(16)(b^2)(L)
where R is the roll rate in pounds per inch, pi is 3.14, G is the modulus of the material; d is the diameter of the bar; b is the length of of the roll bar arm measured from centre to centre; and L is the length of the anti-roll bar.
Generally, the diameter of the bar will have the greatest effect & small changes in bar diameter result in large changes in anti-roll bar rate since it varies as the fourth power.
Paul Bearman is offline
Old 07-17-08, 05:10 PM   #4 (permalink)
wealdenengineer
Rep Power: 0 wealdenengineer has a little shameless behaviour in the past
Paul, 22mm dia Special steel we use.
ID:	31121  Click image for larger version
ID:	31122  Click image for larger version
wealdenengineer is offline
Old 07-17-08, 09:05 PM   #5 (permalink)
Phil's Avatar
Phil
3 Tenths
GT40: scratch built Mk1
Paul
Take a look at the roll bars available in some of the race catalogs. There are straight lengths available in 1" increments, with various diameters. Also available are some really nice arms splined for the bar, with connections for heim joints at the end. Most of the arms can be had in straight and various bent configurations to fit your chassis.
If you really want to get crazy you can get an arm with a bearing and cable attachment to vary the stiffness of the bar as you drive.
Good luck
Phil
Scratch Built Spaceframe, 289, Pin Drives
Phil is offline
Old 07-19-08, 12:42 PM   #6 (permalink)
Ant
Gibbo
GT40: Tornado
Rep Power: 5 Gibbo is on a distinguished road
Hello Paul,
This thread has got me looking. so far the best i can find in terms of a straight splined ant-roll bar is from a Peugeot 106 and that was on Ebay, i haven't been able to find a proper supplier of universal antiroll bars but where theres a will theres EBAY!!!! I think the 205 may have had these type too.
Keep us up to date with your decisions etc so others may follow
I drive a Quantum Car....I don't know where I am going but i'm driving really really fast to get there!!!
Gibbo is offline
Old 07-19-08, 02:11 PM   #7 (permalink)
PDub's Avatar
PDub
6 Tenths
GT40: Tornado
Thanks for all the info guys, I'll give the stainless a miss for the moment as it doesn't seem the best way to go. I'll post if I find anything that i can use.
Best regards,
P.
PDub is offline
Old 07-19-08, 02:15 PM   #8 (permalink)
Ant
Gibbo
GT40: Tornado
Just found that Rally Design do a sierra anti roll bar kit. its a rod with ends type, only 95quid. gonna call them monday to see about lengths. the rod isn't splined just has a hole through the tube so the arms could be easily fabricated i think to make it fit our application
Gibbo is offline
Old 07-19-08, 11:17 PM   #9 (permalink)
Jim C's Avatar
Jim C
Gold Supporter
GT40: RF 105
Rep Power: 9 Jim C will become famous soon enough
Paul
Dont even bother jerking around trying to make it look for it.
Something close but not quite is always a pain in the arse as far as I am concerned
Get copper pipe in a similar size bend it to the shape that you want.
1/2 hour to make a pattern its all over.
Give it to a sway bar manufacturer as a pattern and Shazzam its done.
All you will have to make is the drop links.
Occupation Automotive
Interests are
Fabrication and design
Building my car
Sydney Australia
www.mentalperformance.com.au
Jim C is offline
Old 07-20-08, 10:57 AM   #10 (permalink)
egoman's Avatar
egoman
Canada
Rep Power: 2 egoman is on a distinguished road
If you are looking for splined bars that wont break you go to the oval track supply houses. The sprint cars and midgets use the torsion bars for suspension and they are available in many lengths and rates. They are also available as hollow bars for the weight conscious. Google Afco or Sanders and see what you come up with. Good luck.
egoman is offline
Old 07-31-08, 10:28 AM   #11 (permalink)
Ant
Gibbo
GT40: Tornado
The rally design kit just arrived, first look seems promising. just have to cut arms down to fit the front and the rear looks the same. Probably easiest to fabricate drop links than find ones of the right length.
Gibbo is offline
Similar Threads
Bending Exhaust tube with Sand Lambo GT40 Tech - Chassis,Brakes,Tires,&Wheels 5 04-06-07 10:29 PM
Stainless Steel Specifications David Morton The Paddock 2 02-16-07 03:34 PM
RCR Stainless Steel 180 Header system RCR40 Big-Foot RCR Forum - RCR40 / RCR70 / P4 / MKIV 7 02-04-07 02:23 PM
Stefs Stainless Steel Dry Sump Oil Pan SBF llarsen The Ebay Marketplace 0 12-24-06 07:23 PM
CAV Stainless Steel Moncoque Chassis Bill D All GT40 0 12-03-01 05:24 PM
