Paul,
""I've had a search on the web and found
www.fuelairspark.com who sell the eDist product""
Ok, I called FAST, they say the Accel ECU has preference, the eDist can be set either waste spark or sequential, and either smart coil or regular coil.
""Tell me more about your setup, has the motor been run with the Accell DFI and a normal distributor before?""
No this is a new install, never run.
""Are your injectors currently batch fired (in pairs) and hence you have had no need for the cam sync before? ""
Injectors will be sequential, don't know about the coils, haven't decided on which ones to run.
""If that is the case I would think that you will need to connect the timing signal output from the Accell EFI (mapped ignition) to the appropriate input on the 'eDist' unit, + also provide the crank trigger signal and cam sync signal to the 'eDist' unit.""
that makes sense with sequential injectors, it has to have a cam sync correct?
"" It will then take the correctly 'timed' spark from the ECU output and direct it to the correct coil, or in your case, pair of coils.""
Agree
""With respect to the cam sensor position, I would think that the only thing it governs is which cylinder is about to fire.""
If it's waste spark, if sequential then it needs to know if #1 is compression or exhaust? Excuse me if I repeat the obvious I'm still learning some of this stuff.
""With wasted spark systems, the double ended coils fire once on compression and once on exhaust and hence each of 4 spark signals is directed to a specific pair of cylinders (plugs). Getting the sequence wrong will be exactly the same as mixing up the plug leads on a normal distributor and if you know your firing order, the sequence can be correctly identified fairly easily.""
Agree
""Rather than ramble on about how to determine this, post some more details, firing order, how system is wired and I'm sure this can be sorted relatively easily.""
Ok since FAST said the ECU has preference I actually read the directions for the ECU because I've already purchased the ECU. (but not the FAST eDist yet). It's generic instructions but details several ignition setups, non of which though has the Ford cam sync sensor. The closest description to my setup says take a multi tooth distributor reluctor wheel and break off every tooth but one for the cam sync, and then set it up 45 degrees before TDC #1, which would be like what you first suggested. It doesn't say rising or falling although that can be set either way in the ECU. The only difference would be the duration of the signal because a single tooth from a multi tooth wheel will be much shorter than the Ford cam sync which is about 60 percent rising and 40 percent falling?
So I guess the question is what's better falling or rising for the cam sync signal at 45degree BTDC #1, because the ECU can set either way. And a related question the cam sync event should be at 45 degree BTDC on the COMPRESSION stroke of #1 correct?
And another question, rising edge is when the tooth edge is leaving the pickup, is this the timed event that the ECU is looking at? It's like a switch right and it turns on and off, the ECU is only looking at when it turns on correct? And the rising edge is when it turns on?
""ps - looks like quite a neat product, especially as it is NOT manufacturer specific and can hence be used to enhance many different system configurations. What sort of cost is it?""
It is nice and universal, the Accel doesn't do distributorless (YET). The other choice was the factory Ford EDIS but that has the heavy/ugly 32 tooth crank trigger. The FAST eDist uses the 4 magnet and costs about $300.00. US. It's set up for LS1 coils if you go with smart coils and any coil if using regular, If you have time explain "smart" coil I didn't have time to ask the FAST tech.
""pps - this will make you laugh - how we used to distribute the spark back in 2000 BEFORE switching to Motec and multicoils.""
I remember seeing this pic before, I see an MSD trigger wheel there. It looks like the timing marks are set up for if you lose your reading glasses. 8>)
