Old 08-01-05, 03:55 PM   #1 (permalink)
Bill D's Avatar
Bill D
I Have No Life
Ford\'s Short Water Pump
Is anyone using Ford's short water pump and corresponding timing chain cover? According to Ford's 2005 Performance Parts catalog, they offer a short water pump (M-8501-E351S) that is 1.5" shorter than the standard water pump.
This seems like a no-brainer with the tight fit of the engine space in the GT.
Bill D
Bill D is offline
Old 08-01-05, 04:04 PM   #2 (permalink)
ahirsbrunner's Avatar
ahirsbrunner
Administrator
GT40: RCR-40 #24
Rep Power: 8 ahirsbrunner has disabled reputation
Re: Ford\'s Short Water Pump
Note there is no provision for a mech. fuel pump (or space for the fuel pump eccentric) with the short cover.
Al H.
ahirsbrunner is offline
Old 08-01-05, 04:22 PM   #3 (permalink)
Bill D's Avatar
Bill D
I Have No Life
That's OK. I'm using an electric fuel pump.
My concern is over the limited space in front of the engine. Seems like this is a solution that helps give some needed apace
Bill D is offline
Old 08-01-05, 04:26 PM   #4 (permalink)
mike_starling
Location: 59 years old. Went to college in Florida during the Ford-Ferrari wars. Was a pit steward for the D
GT40: WV
Rep Power: 7 mike_starling has a spectacular aura about
I'm using it on a 4 bolt SVO race block but still had to build all of the front end equipment mounts, pulleys, and idlers to reduce the overall length of things. Because the block requires an external oil pump the front end equipment got complicated and there will still have to be a dimple in the firewall for the a/c compressor pulley.
Were it not for the external oil pump there would have been lots of room with a single belt.
mike_starling is offline
Old 08-01-05, 04:43 PM   #5 (permalink)
Bill D's Avatar
Bill D
I Have No Life
Thanks Mike.
I'm using the 302 Sportsman block that uses the standard wet sump system. Ford also offers special 1-groove and 2-groove pulleys (crank, H2O and alt) that work with the short water pump and cover. I know I will need to make a special bracket for the A/C.
Bill D
Bill D is offline
Old 08-01-05, 04:52 PM   #6 (permalink)
brettmcc's Avatar
brettmcc
GT40: RSGTD
Bill,
Remember Kalun_D's work on eliminating the mechanical pump altogether? See here: http://www.gt40s.com/ubbthreads/showflat...&PHPSESSID=
Might be a thought if you want to find that extra space?
Brett
brettmcc is offline
Old 08-01-05, 07:02 PM   #7 (permalink)
MikeDD's Avatar
MikeDD
GT40: DRB
Houston ...I have a cooling problem.
I'm running the E351 Ford short pump
with a timing cover I "assume" is from a reverse rotation engine,
since it has no boss for the fuel pump.
The pulleys are set up to run as standard rotation.
It appears I'm getting no flow through the radiator
(thermostat has been removed temporarily). At first I assumed this was simply air lock issues...but I'm pretty sure I've bled most of the air out. Now I'm wondering
if the box was mislabled and I'm actually running a
reverse rotation waterpump in the wrong direction,
or if the standard rotation pump is somehow incompatible
with the reverse rotation cover. Opinions ?
Thx
MikeD
MikeDD is offline
Old 08-01-05, 07:24 PM   #8 (permalink)
Bill D's Avatar
Bill D
I Have No Life
Mike-
According to my FRPP Catalog, the E351S water pump is normal rotation. I couldn't find any information about the cover. Sorry.
Bill D
BillD
Bill D is offline
Old 08-01-05, 09:40 PM   #9 (permalink)
ross nicol's Avatar
ross nicol
I'm using the short water pump and it is standard rotation.I did make sure I fitted the correct cover to suit the pump and it doesn't have the mechanical fuel pump holes.I believe the standard rotation suits 'V' belts and reverse rotation flat belt.I have the alternator mounted high and it protrudes through bulkhead, covered by a fabricated panel.Hope this helps, never had a cooling problem in 2 years racing.
Ross
ross nicol is offline
Old 08-01-05, 09:50 PM   #10 (permalink)
CCX33911
GT40: Virginia
Short pump, standard rotation with no v-belts!
CCX33911 is offline
Old 04-05-07, 11:54 PM   #11 (permalink)
Andy 8V
GT40: None yet
Rep Power: 2 Andy 8V is on a distinguished road
Re: Ford's Short Water Pump
May I suggest you scope out a Sunbeam Tiger water pump, which was shortened for fan to radiater clearance. I've heard you or a rebuilder can convert a regular 289 water pump to Tiger specifications with a press and a hacksaw. The Tiger guys may be able to clue you in to a source of the pulley.
Andy 8V is offline
Old 04-06-07, 08:04 AM   #12 (permalink)
porsche93's Avatar
porsche93
2 Tenths
GT40: RF Chassie 90
Rep Power: 8 porsche93 is on a distinguished road
Check this thread.
http://www.gt40s.com/forum/roaring-f...ght=water+pump
Peter
Roaring Forties #80
306CUI, SBF,8 Stack Injection
Motec M800 ECU
Audi 5N with 3.22 Ring and pinion
17 inch Vintage Wheels
Florida Plate # GT40 MK1
porsche93 is offline
