Ford H.O. 351 SVO crate engine #1083 with under 200 miles.
2 bolt main block with nodular iron crankshaft, hypereutectic high silicone pistons and heavy duty truck rods with spot faced seats for 3/8" cap bolts.
SVO (M-49J302) GT40 "turbo swirl" aluminum heads with SVO stainless steel valves (1.94" intake\1.54" exhaust)
Aluminum COBRA valve covers
SVO (M-6250-A351) hydraulic flat tappet cam dual grind (Lift- 0.520 in\0.538 ex Duration- 236* in\246* ex @0.050" valve lift
SVO (M-6268-A302) multi-index true roller timing chain and gears
SVO (M-6500-A303) solid lifters
SVO forged aluminum roller rockers (1.60:1 ratio)
SVO dual valve springs
Ford high volume oil pump
SVO (M-6605-A341) chrome moly pump drive shaft
SVO (M-6375-A302) billet steel flywheel
Valeo 10-1/2" diaphragm clutch and pressure plate
SVO (M-6316-A521) SFI spec 18-1 4-bolt crankshaft damper
Ford Motorsports (M-8501-E351S) standard rotation short water pump
CFI custom billet aluminum pulleys
MSD (#8578) Pro Billet, small cap, HEI distributor
Accel 8mm copper core silicone wire set
Aviaid (155-55361) GT40 6 qt, boxed wet sump, road race oil pan with windage tray, scraper and dipstick
Ford OEM starter (2 included)
Ford OEM alternator
Rolling engine stand
Exhaust header flange set (to make your cross over exhaust system if needed)
Isolated runner IDA Weber intake manifold purchased from Holman Moody has carb mounting pads machined at 10 degree angle to facilitate fitting a MK1 GT40 airbox
Custom fabricated aluminum turkey pan, backfire plate
6AN fuel supply line with pressure regulator, gauge and linkage.
Genuine vintage 48IDA Weber carbs sandcast in Italy. All are 48IDA-4, numbers 4572, 4747, 4778 and 4886, rebuilt and setup by Inglese Induction Systems in Wallingford CT. and dyno tuned at Opel Engineering in Streamwood, IL with 2.5" spun aluminum velocity stacks installed.
Chrome steel velocity stacks with caps, box of idle and main jets, air correctors and emulsion tubes for tuning, air filters, rings and screens are also included. 3 books on Weber carburetors and Inglese setup manual
$25,000.00+shipping
Ford OEM alternator
$25,000.00+shipping
