Old 11-04-06, 03:47 AM   #1 (permalink)
Brian Kissel
Rep Power: 9 Brian Kissel is on a distinguished road
Question 460 Ford help needed
This is not Gt40 related, but for a Cobra replica. There seems to be some of the best brains on this forum, and I would like to pick them for a moment. Recently a fellow brought me a 460 to rebuild out of a Cobra he recently purchased off Ebay. The engine came to me without the oil filter on it. Now it is time to reinstall the engine, and I haven't found a short enough oil filter. The common short unit is still way to long. He did not keep the old one so I could not get a manufactuer and a part number for it. He seems to think it was only about 2 1/2 inches long. I also do not find the manufactuer name on the car so I might contact them either. I know some of you gentelmen have Cobras also and might be able to offer a solution.
Thank You for any help you might be able to offer.
Regards Brian
If you are not living on the edge, you are taking up too much space !!!!
Brian Kissel is offline
Old 11-04-06, 04:28 AM   #2 (permalink)
jac mac's Avatar
jac mac
New Zealand
Rep Power: 19 jac mac has much to be proud ofjac mac has much to be proud of
Re: 460 Ford help needed
Hi Brian,
If you only have 2.500" of space to fit a filter I would look into fitting a remote filter of a standard or larger size. Any of the circle track sites should be able to help you with the ,Filter mount & bracket, Block adaptor, Hoses & Fittings. The 460 uses the same filter as any small block Ford , Use -10 hose & Fittings.
Jac Mac
jac mac is offline
Old 11-21-06, 12:41 PM   #3 (permalink)
mustanger
Sweden
GT40: gtd 5,0 ho weber trickflow
Rep Power: 4 mustanger is on a distinguished road
you have to use a ford motorsport m-6880-a50 angle adaptor
mustanger is offline
Old 11-22-06, 01:48 AM   #4 (permalink)
Rick
Rep Power: 3 Rick is on a distinguished road
http://http://cgi.ebay.com/ebaymotor...Z8053136507QQr
Z1QQsspagenameZWD1V
This is one type of oil filter adapter available. The OEM one was used in F250 pickups and Econolines and mounted the filter at about 30-45 degree angle to the block to avaoid frame interferance.
Rick is offline
Old 12-01-06, 09:54 PM   #5 (permalink)
LedheadELH
Rep Power: 2 LedheadELH is on a distinguished road
I had a similar issue in a vehicle I swapped an FE into. I found that the oil filter from a 00' or so Ford F-150 had a real short oil filter, that had the same thread and stuff as the old filter that all other ford motors had, like my FE, and your 460. I can't remember the exact legnth of that filter, but it was like half as long as the regular ones.
I eventually ended up w/ an oil filter relocator from summit for $40.....best thing I ever did for an oil filter!.....made changing the oil WAY easier!
LedheadELH is offline
Old 12-02-06, 01:28 AM   #6 (permalink)
car guy's Avatar
car guy
GT40: Bailey Edwards
Rep Power: 4 car guy is on a distinguished road
I had a similar situation on a SBF. I don't know if a FE 460 uses the same size screw-on filter, which if memory serves me right is a 3/4" x 16. I ended up calling the Mobil 1 "hot line" and they were able to designate a filter that worked. It also was quite short (about 3") and came from a Lexus. You might give them a call. Good luck.
car guy is offline
Similar Threads
Who owns the rights to the GT40 Body? ChrisMartino All GT40 112 06-08-08 02:38 PM
Ford 302(347) / Audi 016 adapter needed carlos GT40 Tech - Powertrain/Transaxles 9 06-15-06 12:34 PM
Ford Monaco Red Paint Code Needed AluminumGT40 GT40 Tech - Exterior, Interior, AC, & Trim 1 08-17-05 10:59 PM
Ford showroom mural Andre40 The Paddock 2 01-04-05 03:36 AM
GT40 References toner GT40 Tech - Exterior, Interior, AC, & Trim 13 11-16-03 08:05 AM
