Old 12-21-06, 10:59 PM   #1 (permalink)
markg
Rep Power: 3 markg is on a distinguished road
whats this motor???
Hi Guys,
New poster here. I have a motor with casting number C6FE 6015 A. Someone at Ford forums suggested that it was a 1966 Ford GT 40 motor. my fingers are crossed!!! Have I hit the jackpot? thanks, mark
markg is offline
Old 12-21-06, 11:13 PM   #2 (permalink)
Bill D's Avatar
Bill D
I Have No Life
Rep Power: 35 Bill D has much to be proud ofBill D has much to be proud of
Re: whats this motor???
Anything is possible, but I doubt anyone would seperate a GT40 from it's engine.
Your casting number breaks down as follows:
C6 = 1966
F = Outside US, T/A racing
E = Engine
A = 289/302 motor
Bill D
RCR GT40 Mk1 Gulf
Bill D is offline
Old 12-21-06, 11:57 PM   #3 (permalink)
markg
thanks bill. The car came from the UK so the "outside US" makes sense. What does TA race mean? Is it a race specific motor, different from a std 289? What other things can I check to see if it's a gt40 motor?
markg is offline
Old 12-22-06, 12:53 PM   #4 (permalink)
Bill D's Avatar
Bill D
I Have No Life
T/A = Trans Am
If it still has it's original oil pan, it would be a dead giveaway.
Bill D
RCR GT40 Mk1 Gulf
Bill D is offline
Old 12-22-06, 03:39 PM   #5 (permalink)
markg
thanks Bill, what am I looking for on the oil pan? Also, does the "F" mean foreign OR trans Am, or Foreign AND Trans AM?
markg is offline
Old 12-22-06, 04:55 PM   #6 (permalink)
JIMMYMAC
Rep Power: 17 JIMMYMAC has much to be proud ofJIMMYMAC has much to be proud of
Mark,
You may have hit the jackpot as C6FE 289 blocks were used on early GT40s and Cobras.
What are the rotating part numbers ?
Does it have "RAC" stamps on any machined faces ?
The oil pan is still an out-shop part to this day and will not signify a true GT40 racing engine.
Cordially,
James
Graviner Fire Suppression
JIMMYMAC is offline
Old 12-23-06, 10:57 AM   #7 (permalink)
markg
thanks Jim, what other part numbers should I be looking for and where can they be found. the motor is currently running but I can take it apart if need be. Thanks, mark
markg is offline
Old 12-23-06, 12:18 PM   #8 (permalink)
JIMMYMAC
Mark,
If the long block has it's original iron heads they should read C6FE also.
If they have been professionally ported for racing the shop name will probably be stamped on the heads.
Crank must be forged steel and part numbers may start SK or XE
Piston head part are SK 368666
Ford Indy rod part are SK 34375
These will by no means connect your engine to an original GT40 car, but if they are present you will have a very nice 289 racing engine.
I reckon that you must be getting quite a lot of personal mail by now.
Post a picture if you can.
Cordially,
James
JIMMYMAC is offline
Old 12-23-06, 04:30 PM   #9 (permalink)
JIMMYMAC
Mark,
I now think the rod numbers are for a 302 engine, however the SK still stands.
Cordially,
James
JIMMYMAC is offline
Old 12-23-06, 04:46 PM   #10 (permalink)
markg
thanks Jimmie, can I see the head part numbers by pulling the valve covers or do I have to pull the heads?
markg is offline
Old 12-23-06, 05:15 PM   #11 (permalink)
JIMMYMAC
Mark,
See the photo of the numbering on the front of a C6FE head
Name:	C6FE HEADS08.jpg
Cordially,
James
JIMMYMAC is offline
