| Notices | Hi member,
Enjoy the forum!
03-07-07, 09:36 PM
#1 (permalink)
| | toy264 Moderator
Rep Power: 6  | What do you saftey wire? The engine/transaxle that came in my car had the primary exhaust pipe to engine cap screws, and the half-shaft to transaxle drive flange bolts saftey wired, which seemes pretty reasonable. What other fasteners so you serious racers consider important to wire? |
03-08-07, 10:09 AM
#2 (permalink)
| | crossle43 Lifetime Premier Supporter
Join Date: Nov 2004 Location: Arlington, WA GT40: RCR40 #27
Rep Power: 9  | Re: What do you saftey wire? John,
Pick up a copy of Carrol Smiths book, 'Prepare to Win.' I promise you, anything and everything that has to do with preparing a winning car will be found inside. An excellent read and highly recommended.
One thing it does not cover, however, is the loose nut behind the wheel...
Best,
T.
__________________ Every job is a self-portrait of the person who does it... autograph your work with excellence - unknown |
03-08-07, 10:20 AM
#3 (permalink)
| | speed220mph A Tenth
Join Date: Feb 2003 Location: North Carolina GT40: ERA GT
Rep Power: 7  | Re: What do you saftey wire? John: Safety anything you don't want to come loose or you'd like to visibly check if the fastener has loosened such as wheel knock-offs. Where it's not practical to use nylocks or other locking devices on critical nuts or bolts such as steering and suspension components, wire them. Not so easy are ZF gearbox ring gear-to-carrier bolts. They should be Loctited and safety wired, too.
Ditto on Carrol Smith's books.
__________________ "History does not entrust the care of freedom to the weak or timid."
- Dwight D. Eisenhower |
03-08-07, 11:08 AM
#4 (permalink)
| | sfm6s Rookie
Rep Power: 4  | Re: What do you saftey wire? Quote: |
Carroll Smith covered that subject in 'Drive to Win' ISBN 0-9651600-0-9 |
03-08-07, 04:30 PM
#5 (permalink)
| | shrjr110 Rookie
Rep Power: 4  | Re: What do you saftey wire? Does anybody know anything about safe-t-cable made by DMC??
Aviation guys?
Thanks,
John |
03-08-07, 04:47 PM
#6 (permalink)
| | Scott Calabro Tonado USA Rep
Join Date: Oct 2006 Location: New England GT40: TS40 # 875
Rep Power: 13  | Re: What do you saftey wire? Hi John,
We have a Daniels Manufacturing Corp. Saftey cable tool at work. Its works fantastic.....
Scott
We use it for safties that are very difficult to access. Situations where your hands can't go, but are accessed in a straight line. We however do not use them for safties that will be inside a component part with rotating/moving parts. Like a transmission. In that situation only .040 wire would be used. Of course there might be an application that I have not seen yet, that does use the Daniels tool for those situations.
Reason: content
03-08-07, 08:09 PM
#7 (permalink)
| | YerDugliness Lifetime Premier Supporter
Join Date: Mar 2006 Location: near Houston TX GT40: Yellow Wix MKII
Rep Power: 9  | Re: What do you saftey wire? Quote: |
Originally Posted by toy264 The engine/transaxle that came in my car had the primary exhaust pipe to engine cap screws, and the half-shaft to transaxle drive flange bolts saftey wired, which seemes pretty reasonable. What other fasteners so you serious racers consider important to wire? | Perhaps the most common use for safety wires I've seen involves the bolts holding the flywheel to the crankshaft. Loc-tite has always worked for me, but I've known others whose bolts backed out. Not pretty.
I notice Scott's post above mentions not using safety wires in a rotating component (or perhaps he's referring to using the Daniels tool rather than safety wiring in general). As for using wire on the flywheel bolts, I've often wondered what effect that might have on the engine balance.
Doug
__________________ YD,E./PNB
Retired and attempting to age disgracefully |
03-08-07, 08:24 PM
#8 (permalink)
| | toy264 Moderator
Rep Power: 6  | Re: What do you saftey wire? Any tips on drilling the cap screw heads- I seem to break at least one drill bit every other part (yes, I use a fixture on the drill press, and the bits are sharp  I've thought about getting some eloxed (EDM) but it's expensive for just a few parts. |
03-08-07, 09:13 PM
#9 (permalink)
| | wbmusarra 10 tenths
Join Date: Oct 2001 Location: Snellville, Ga. GT40: DRB#5
Rep Power: 21  | Re: What do you saftey wire? Pegasus racing supplies has all the AN size bolts that you would ever need and they come in completely undrilled, drilled shank only, drilled head only or drilled head and shank. All you have to supply is the nominal lenght and the grip lenght. Prices run from $.19 to around $8-10 apiece. Most of the drilled ones you would have to call for pricing. Saw one for as high as $17, but one, one half inch shorter in lenght was only $2.59. Go figure
__________________ DRB#5
351W/408 DIS TWM F. I. 930 Porsche LSD |
03-08-07, 10:01 PM
#10 (permalink)
| | jcdean Rookie
Rep Power: 2  | Re: What do you saftey wire? I work for the FAA in the Flight Inspection area. The Daniels tool has been a great addition at our hangar as well. Wire and a zip tool are still the preferred method, but the Daniels straight pull has never failed us either.
__________________ Joey |
03-09-07, 02:46 PM
#11 (permalink)
| | toy264 Moderator
Rep Power: 6  | Re: What do you saftey wire? Quote: |
Best,
T. | T.--
I read through Smith's book last night, and agree that is a terrific read! I was surprised to see how adamant he is against the use of SAE grade fasteners, at least for fine threads! All this time I've paid the extra for grade 8 hardware thinking it was the best! Now I have to find a source for AN/MIL spec aircraft fasteners. At least they can be had pre-drilled.
Like Roseanne Roseanadana says, "It's always something."
John |
03-09-07, 03:08 PM
#12 (permalink)
Originally Posted by toy264 Like Roseanne Roseanadana says, "It's always something."
John | One of my favorite lines, John! Good to see that great minds think alike!!
Doug
03-09-07, 06:11 PM
#13 (permalink)
Rep Power: 13  | Re: What do you saftey wire? Hey Dudes !
Dug...
I would'nt use the Daniels tool inside a component part like a transmission.
Safety wire WON'T affect the balance to ANY degree that would be of negative consequence on a GT40.
John...
Altough you can purchase so called "AN" or "MS" hardware from non aviation sources, if you wan't the real deal, buy from a source like AVIALL or another industry source.
Bogus hardware is a HUGE problem in aviation and I would suspect that what you get from a speed shop is a fake. An aircraft supplier will provide documentation of the hardware's authenticity.
Go to FAA.GOV, download a copy of AC43.13 1B, or buy one.
You'll dig it !
toy264...
Buy the real thing, then you won't have to bother with drilling.
jcdean...
What do you do for the FAA?
Best regards,
Scott
Reason: spelling !!!
LinkBacks (?)
LinkBack to this Thread: http://www.gt40s.com/forum/gt40-tech-engines-induction-exhaust/21058-what-do-you-saftey-wire.html | | Posted By | For | Type | Date | | GT40s.com | This thread | Refback | 03-07-07 09:46 PM | | GT40s.com | This thread | Refback | 03-07-07 09:45 PM | |
