Old 01-23-08, 11:23 AM   #1 (permalink)
Ron Earp's Avatar
Retiree
Post Engine Oil Adapter, Remote Oil Filter / Cooler
I have been looking for a rather unique piece for my 260Z race car and finally found it. What I wanted was a remote oil filter adapter that had more than two ports so I could easily hook up a oil temp and oil pressure gauge, maintain a spin on filter at the block, and easily hook up a oil cooler. Well, I finally found it on Ebay:
I got the piece yesterday and it is awesome. Has plenty of adapters with it, looks like it will do exactly what I wish to do. Maybe you guys were already aware of these, but I'd not seen them in Jegs or Summit and this elegantly solves the problem I had.
Ron
Ron Earp is offline
Old 01-23-08, 11:43 AM   #2 (permalink)
brettmcc's Avatar
brettmcc
GT40: RSGTD
Re: Engine Oil Adapter, Remote Oil Filter / Cooler
Ron,
Good find. I was aware that Mocal did them with 1 port,but that makes things a whole lot easier.
Brett
brettmcc is online now
Old 01-23-08, 01:48 PM   #3 (permalink)
Mark Clapp's Avatar
Mark Clapp
4 Tenths
GT40: Mark I (South Africa)
Rep Power: 12 Mark Clapp is a jewel in the rough
Ron, is the adaptor thermostated to bypass the oil cooler until the oil temp is up?
Kit Car Centre Mk I (South Africa)
Mark Clapp is offline
Old 01-23-08, 02:40 PM   #4 (permalink)
Ron Earp's Avatar
Retiree
No, you just have to be careful on oil temps and throttle. Never had a problem with that except one track event and it was 26F. Just put cardboard over half the cooler and took care of that. But anything over 50F and she's about right on the money with the cooler size and Z motor.
Ron Earp is offline
Old 01-23-08, 10:45 PM   #5 (permalink)
Big-Foot's Avatar
Big-Foot
Gold Supporter
GT40: RCR40 - #45
Rep Power: 23 Big-Foot has a brilliant futureBig-Foot has a brilliant futureBig-Foot has a brilliant future
Looks like a tidy little piece of work there!
Regards - Randy
Big-Foot is offline
Old 01-24-08, 09:54 AM   #6 (permalink)
wbmusarra's Avatar
wbmusarra
GT40: DRB#5
Rep Power: 21 wbmusarra is a name known to all
I like the adapters, but would like to keep the remote oil filter that I have. Is there a way to cap off the oil filter adapter? Otherwise I will take my swivel Mocal unit and tap it for the sensors. Trying to adapt the remote unit is like an erector set for mine. I have oil temp, pressure and fuel pump cutoff for low pressure, as well as warning lites for temp and pressure. May have to T some of them.
DRB#5
wbmusarra is offline
Old 01-24-08, 02:22 PM   #7 (permalink)
Russ Noble's Avatar
Russ Noble
New Zealand
GT40: Building scratc
Easiest way Bill is to cap it off with another filter! Nothing wrong with running two filters so long as you have a sufficiently uprated pump.
Otherwise it's not difficult to machine up a hollow alloy spin on cap grooved for an o ring seal. You could also drill it in the side for as many extra senders etc that you want to run. You will need something like these take off ports to drill through into the centre boss to enable the oil flow any way. There's a couple of different ways to skin this cat, if you want diagrams let me know.
There again someone may make an adaptor like Rons that is already capped i.e. doesn't have provision for the filter....?
Russ Noble is online now
Old 01-24-08, 02:33 PM   #8 (permalink)
Ron Earp's Avatar
Retiree
This one is what you'd want, four 1/2" NPT ports.
Ron Earp is offline
Old 01-24-08, 03:12 PM   #9 (permalink)
jac mac's Avatar
jac mac
New Zealand
Rep Power: 23 jac mac has much to be proud ofjac mac has much to be proud of
Can re-design this to give a Filter/Cooler in one unit-only two hoses reqd. Intend to make one for my car with 2.5" OD in the cooler area so that it can fit up the tunnel.
Name:	down loading camera dec 07 004.jpg
jac mac is offline
Old 01-24-08, 08:26 PM   #10 (permalink)
Mark Worthington's Avatar
Mark Worthington
GT40: Massachusetts
Rep Power: 26 Mark Worthington will become famous soon enough
So who was the ebay vendor, Ron?
Mark
347, MoTeC EFI, pin drives, leather, etc.
Mark Worthington is offline
Old 01-24-08, 10:12 PM   #11 (permalink)
wbmusarra's Avatar
wbmusarra
GT40: DRB#5
I Googled Maxspeed Motorsport and they had one on auction for $69. It only had one hour left on it when I asked my question. I already have the mocal remote filter adapter mounted on the side wall of the engine bay and a thermostat/bypass mounted between the filter and the cooler. Then there is the Accusump which is T'd off the return line with it's one way valve tied in to prevent pack flow. The filter mounting has two extra 1/2" ports which are available. They require several pieces to put the small tubing of the oil pressure line. the other one would have to have a T so that the temp adapter(1/2") can occupy one side and then adapters to fit the fuel pump cutoff and the warning lite. So you can see how this adds up. Will consider tapping the sandwich adapter for the pressure and the fuel pump cutoff, leaving the two 1/2s for the temp gauge and over temp lite.
I had considered tapping into the sandwich adapter earlier due to the erector set that would be required for the other pieces. Just wasn't sure that was the way to go. Looks like that is the way to go now. Cost would be about the same.
DRB#5
