Old 03-22-08, 06:20 AM   #1 (permalink)
p thompson's Avatar
p thompson
Administrator
GT40: None
LS1 ignition timing??
Hi all -
A friend with a Lola T70 spyder rep is having a few difficulties with the timing on it's LS1 motor installed so whilst not GT40 - I figured one of you might be able to help/advise.
His motor has an edlbrock cam with a mild 220/220 .510 profile and produced 400HP at the hubs on a dyno. However, it pings quite badly higher up the range. He has an MSD 6010 unit and is running UK 95 octane fuel.
Anyone got any thoughts on the timing requirements? - I know little of LSx technology and whilst each engine is different, I have have heard that they don't like much ignition WOT...
Over to you chaps....
regards
Paul Thompson
p thompson is offline
Old 03-22-08, 08:17 AM   #2 (permalink)
Keith1's Avatar
Keith1
GT40: Uh uh
Rep Power: 25 Keith1 has much to be proud ofKeith1 has much to be proud of
Re: LS1 ignition timing??
Is that a SBC?
10-12 initial 34-36 deg total all in by 3k I would have thought as a starting point much like any V8. I ran Moroso octane booster + unleaded pump gas without problems in my 11:1 cr SBC with around 550 hp, but I think the RON was higher than 95.
Does the motor run hot?
Yours Sincerely, Keith Hardy
Keith1 is offline
Old 03-22-08, 02:27 PM   #3 (permalink)
p thompson's Avatar
p thompson
Administrator
GT40: None
Thanks for reply Keith -
For more details re LS1s..
Google Image Result for http://www.camarotech.com/images/LS_engine_coil_covers_graphite_intake_500.jpg
Not sure whether it's running hot or not - I'll ask.
regards
Paul Thompson
Old 03-22-08, 03:43 PM   #4 (permalink)
jac mac's Avatar
jac mac
New Zealand
Rep Power: 19 jac mac has much to be proud ofjac mac has much to be proud of
I would be surprised if those motors require more than 32° total to make good power, maybe even as low as 28/30°, given the plug location/compact chamber/smaller bore etc.
jac mac is offline
Old 03-22-08, 08:33 PM   #5 (permalink)
Keith1's Avatar
Keith1
GT40: Uh uh
Thanks for the link, that's obviously a new generation SBC.. and probably different from the old 355 Bowtie I was running....
Keith1 is offline
