Old 04-14-08, 07:16 PM   #1 (permalink)
RamboLambo
GT40: Whangarei New Z
Rep Power: 8 RamboLambo is on a distinguished road
Rolling Roads
Could anyone tell me, about power figures that are quoted using rolling roads.
Now - heres my question. In what gear are readings taken? To put it like this, if you took a reading in first gear, there would be more torque available to run the rollers, and hence a higher figure than in say 5th gear. Does the measurement program re-calculate the figures based on the gear ratios used?
Any ideas?
Bruce
RamboLambo is offline
Old 04-14-08, 10:31 PM   #2 (permalink)
Howard Jones's Avatar
Rep Power: 25 Howard Jones is a jewel in the rough
Re: Rolling Roads
I have limited experience I have with chassis dynos but I believe that the gear that is closest to 1:1 is the best choice. I have never seen anyone do it any other way. In most cars this will be 4th. This will provide data that doesn't require a ratio conversion factor.
For example, if you used 2nd and it was 2.00:1 then you would need to divide the resulting data by 2. On the other hand if you used 5th and it was 0.8:1 you would need to multiply by a factor of 1.2.
If I am wrong on this then I am sure you will see the correction posted very quickly.
Howard Jones is offline
