Old 03-30-06, 01:16 PM   #1 (permalink)
Bill D's Avatar
Bill D
I Have No Life
Window and light cover attachment
What is everyone using to attach their Lexan windows and light covers to the body? [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
Bill D
Bill D is offline
Old 03-30-06, 02:20 PM   #2 (permalink)
MikeDD's Avatar
MikeDD
GT40: DRB
Re: Window and light cover attachment
I've seen pan head screws and countersunk screws, used with and without rivnuts/threaded inserts. Depends how often you plan to remove
them. The windows shouldn't be off very often...but the covers probably would since you must remove to clean
inside or maybe change a bulb.
IMHO, countersinking is pretty...but not original, and more likely to crack the lens/lexan.
MikeD
MikeDD is offline
Old 03-30-06, 03:03 PM   #3 (permalink)
Bill D's Avatar
Bill D
I Have No Life
Size? #4, #6, #8, #10??
Bill D is offline
Old 03-30-06, 03:07 PM   #4 (permalink)
Mark Clapp's Avatar
Mark Clapp
4 Tenths
GT40: Mark I (South Africa)
Rep Power: 12 Mark Clapp is a jewel in the rough
Bill, I sent you a PM about mounting the covers. I chose #6 screws as I think #8s are too big going by pics of original GTs.
Mark Clapp is offline
Old 03-30-06, 07:46 PM   #5 (permalink)
Bill D's Avatar
Bill D
I Have No Life
Got it Mark. I sent a reply. I may call this weekend to pick your brain some.
Bill D is offline
Old 03-30-06, 09:01 PM   #6 (permalink)
Ron Earp's Avatar
Retiree
I made some measurements of some originals and like it has been said, #6 was damn close. I'd put nutserts in the glass so you can remove them - any and all track day organizers, except I think Shelby CLub, will require the windows to be off.
Ron
Ron Earp is offline
Old 03-30-06, 11:14 PM   #7 (permalink)
Pantera1889's Avatar
Pantera1889
GT40: RCR MK1
I mounted mine the same way the Safir car I inspected was mounted.With 10-32 nylon screws.
The windows on the Safir car were also sealed in with RTV.
I found black nylonscrews from McMaster Carr.
Pantera1889 is offline
Old 12-07-06, 11:37 AM   #8 (permalink)
speed220mph's Avatar
speed220mph
GT40: ERA GT
Rep Power: 7 speed220mph is on a distinguished road
Thumbs up Re: Window and light cover attachment
I'm too late to provide info for Bill, but I recommend for future builders to use #8-3/4" long stainless-steel sheet-metal screws with #2 Philips drive truss-heads threaded into the fiberglass body. Use truss-head rather than pan-head or oval-head screws. The truss-head has a larger diameter, which provides additional bearing surface on the plastic. What Ron says about nutserts is good. You'll then have to go to machine screws when using them. As for Shelby events, I noticed that an original GT40 ran the SAAC 31 at VIR without side glass required or not. Safety is one reason, but ventilation in another, particularly when running without air-conditioning.
Grainger has made it a whole lot easier for builders. They now have about every fastener you'll ever need. Beats going to your local hardware, Lowes or Home Depot just to find out they don't have quite what you need. Plus, the cost for a box of 100 screws is about 50% more than a package of 10 from a retail outlet.
"History does not entrust the care of freedom to the weak or timid."
- Dwight D. Eisenhower
speed220mph is offline
Old 12-07-06, 07:09 PM   #9 (permalink)
llarsen's Avatar
llarsen
GT40: Sabre
I guess I am the only one who has used #6 rubber well nuts with #6 SS machine screws, but I love them and I'll never worry about the composite flacking or cracking or nutserts coming loose as a result or pulling out on their own. The only caveat is that you have to use SS since the nuts in the well nuts are brass.
BTW, if you are worried about the thickness of the flange or the height of the well nuts, a few seconds on the grinder wheel can re-configure them to your liking.
Lynn
Sabre GT40/5L EFI/G50/50
Always verify parts or products discussed for your own use.
llarsen is offline
Old 12-08-06, 11:51 AM   #10 (permalink)
speed220mph
GT40: ERA GT
Lynn: You took the words out of my mouth. Wellnuts don't pull down hard as do nutserts, which will shatter fiberglass. Nutserts are fine when using with sheet metal, but not f/glass. Also, Wellnuts have an insulating quality, i.e., damp vibrations. If you really want a window that will come out quickly, consider installing about five tabs to mount Dzus fasteners. Although not original, this would make it a whole lot easier than storing a bunch of screws while the windows are out.
Old 12-08-06, 03:55 PM   #11 (permalink)
jonathans's Avatar
jonathans
Silver Supporter
GT40: RCR
Rep Power: 7 jonathans is just really nice
I like the idea of the well nuts. I may get some 1/4 20 well nuts for attaching things like the fuel pumps to help in noise isolation and some small ones for attaching the lexan. I had bought a bunch of rivit nuts but I think I will set them aside for some other project.
RCR GT40
Build Page: https://home.comcast.net/~jonathanstrain/
jonathans is offline
Old 12-08-06, 06:48 PM   #12 (permalink)
steve c
Steve
GT40: SPF GT40 P2125
Rep Power: 7 steve c has a spectacular aura about
Lynn (or anyone who can help)...What is a "well nut"...any pics? How installed?? Any pics of well nuts installed in window and will they allow a flush fit??...Will they prevent plexi from cracking as well as allow easier removal???....HELP....Steve
steve c is offline
Old 12-08-06, 08:52 PM   #13 (permalink)
jonathans's Avatar
jonathans
Silver Supporter
GT40: RCR
http://www.mcmaster.com/nav/framewor...s&dscIDs=40996
RCR GT40
Old 12-08-06, 08:55 PM   #14 (permalink)
jonathans's Avatar
jonathans
Silver Supporter
GT40: RCR
The link did not work. Go to McMaster-Carr and type "wellnut" in the search window.
RCR GT40
Old 12-08-06, 09:51 PM   #15 (permalink)
steve c
Steve
Jonathan....Tx for direction to Mc Masters...I have seen these B4 but, didn't associate w/ "well nut"....Lynn...doesn't the rubber outer lip cause the window to not seal? If the rubber collar is trimmed off to allow the window to seal against the door frame the rubber sleeve won't compress as the screw is tightened...right??Am I missing something?? Tx Steve
steve c is offline
Old 12-09-06, 10:39 AM   #16 (permalink)
jonathans's Avatar
jonathans
Silver Supporter
GT40: RCR
I was going to use rivet nuts which would have caused the same issue with the window not sealing. I think I will use some form of weather strip between each well nut.
RCR GT40
Old 12-09-06, 11:57 AM   #17 (permalink)
Bill D's Avatar
Bill D
I Have No Life
I'm using 8-32 nutserts that have a tiny lip to keep it in. I tried the insert tool, but it casues the fiberglass to crack. And the recessed lip for the plexiglass to sit in posed another problem. So I JB welded them in. But to address the small raised area that makes sealing out the elements problematic, I'm adding 1/8" thick by 3/8" wide adhesive-backed weather sripping to the window edge. McMaster-Carr has a wide assortment. I can get the part number of the type I'm using for anyone interested.
Bill D
Bill D
RCR GT40 Mk1 Gulf
Bill D is offline
Old 12-09-06, 12:39 PM   #18 (permalink)
Mark Clapp's Avatar
Mark Clapp
4 Tenths
Another way to eliminate the well-nut or nut-sert lip and to get a below surface fit is to install heli-coils. You simply drill and tap the body with the tools in the installation kit and thread the coils into the body for permanent threads that never move. They are stainless steel and allow easy removal of the plastic pieces over and over again. Again, McMaster Carr has the installation kits that includes a fantatsic drill bit, the coil thread-in tool, and extra coils for a reasonable price. No cracking of the body or paint.
Kit Car Centre Mk I (South Africa)
Old 12-09-06, 01:01 PM   #19 (permalink)
Brian McCarthy's Avatar
Brian McCarthy
GT40: GTD
Rep Power: 12 Brian McCarthy is a glorious beacon of light
That's what I did, Heli-coils in the body with black plastic screws to hold the lexan down. Probably belts and suspenders, but to retain the coils I put a dab of slow set instant glue into the hole before threading in the insert. Takes a few to get the technique down, but when you establish a process it's slick. I also used them for the sides and rear window. I ended up with 116 coils in the body overall.
Brian
...GTD-40
...LHD-LHS
...302 Roller Block
...R-21
...BRM Pin Drive wheels
...Gulf livery
Brian McCarthy is offline
Old 12-09-06, 07:48 PM   #20 (permalink)
llarsen's Avatar
