Thanks all! If I upgrade from the screws only I think Brian and Marks helicoil solution will be best for me as the car is painted and I don't want to mod the fiberglass or worry about the rubber well nuts bottoming out too early....I have used helicoils B4 in metal but, good to know will work in Fglass ( have you guys had long term experience w/ this use??)....So if I use the tool...add a little quick set epoxy to the helicoil B4 insert should be OK; ...no Fglass cracks????Prob a good idea to oversize the holes in the plexi to let it float a bit (better for temp cycles to prevent cracking of the plexi)?????If I start w/ holes already drilled in the plexi and Fglass I assume I can just open them up to the proper dia and all should align???What w/b the best machine screw head to use ( I think I perfer ss vs a plastic screw although the plastic prob is less likely to crack the plexi????). Thanks for any further input.....Steve
