Old 06-29-09, 02:50 AM   #1 (permalink)
Pete's Avatar
Pete
GT40: GT40 Australia.
Trouble with Vinyl.
Hi, my Ford GT-P's vinyl stripes on the bonnet have been degraded and crazed by either the sun or the engine heat and look crappy.
I have tried removing them using the hair dryer method but no go.
Does anyone know of a product/solvent that will remove the vinyl and glue without effecting the paint?
Cheers, Pete.
DRB chassis 48.
Queensland Australia.
Pete is offline
Old 06-29-09, 03:00 AM   #2 (permalink)
Lynn Erickson
GT40: custom mid eng.
Re: Trouble with Vinyl.
heated razor blade tool $8 in the us
- Harbor Freight Tools - Quality Tools at the Lowest Prices
Lynn Erickson is offline
Old 06-29-09, 03:12 AM   #3 (permalink)
JIMMYMAC
GT40: Monocoque
Pete,
Some ideas here
The bottom link is Australian
Vinyl Graphic Removal Made Easy
http://www.signs.org.au/blaster_order_form.pdf
James
Monocoque, Original MKI Engine & Drivetrain
Graviner Fire Suppression
JIMMYMAC is offline
Old 06-29-09, 03:28 PM   #4 (permalink)
550spydr's Avatar
550spydr
4 Tenths
GT40: GTD
Heat gun and plastic razorblade.
Eric Johnson
GTD 347 w/Webers R30
550spydr is offline
Old 06-29-09, 04:33 PM   #5 (permalink)
brisca943's Avatar
brisca943
In the past I have used some rapid remover from a company called www.thevinylcorporation.co.uk This used with a plastic blade should do the trick. I presume you will have similar products in the states. Would be advisable to try on a small part of the paint which is not visable first but has been fine on the factory paints here in the uk. You have to watch how long you leave it on for for it to work effectively.
Hope this helps
brisca943 is offline
Old 06-29-09, 05:15 PM   #6 (permalink)
Mark Charlton's Avatar
Mark Charlton
Canada
GT40: GTD #9988
There are some tools that are essentially rubber wheels that rub the vinyl off and don't mar the paint. I've used these to remove pin-stripe vinyl and small amounts of lettering to great success and with zero paint damage.
Sign Supplies and Equipment: Stripe Eliminator - Tool to assist in vinyl removal - Low Price Guarantee
When larger areas of vinyl are involved, I use heat and my fingers. It's painfully slow, but doesn't damage the car paint. Even cracked vinyl should come off easier if it's warm. The glue residue can be removed with a commercial sign vinyl solvent (see link below) or using "rubber cement thinner" available from most graphic supply/art shops.
Sign Supplies and Equipment: Orange Peel Adhesive Remover - Remover - Low Price Guarantee
The links above are just so you know what to look for. These should be suppliers in Aus that can get it to you easier than from the US.
Mark
Mark Charlton
____________
GTD40 #09988
71 DeTomaso Pantera
70 DeTomaso Mangusta
Mark Charlton is offline
Old 06-29-09, 07:32 PM   #7 (permalink)
Pete's Avatar
Pete
Thanks everyone, as always most helpful.
Cheers, Pete.
DRB chassis 48.
Pete is offline
Old 06-29-09, 09:53 PM   #8 (permalink)
Phil's Avatar
Phil
5 Tenths
GT40: scratch built Mk1
Pete:
The tool that Mark mentions works really well. I have a version sold by Snap-on, don't know if you can get that stuff down your way. The rubber is a tan color and actually smells like vanilla, the wheel turns rather slowly so as not to burn the paint. I have taken stripes off that have been on paint for some years.
Also, try soaking the vinyl with mineral spirits, a friend of mine who does vinyl signs uses it to remove old stuff before applying new decals.
Phil
Scratch Built Spaceframe, 289, Pin Drives, ZF Box
Phil is offline
Similar Threads
Damaged and in trouble Bernie Knight All GT40 7 04-13-09 11:10 AM
***Vinyl Sun Visors*** ChrisMartino Vendor and Manufacturer Announcements 12 12-18-08 08:55 AM
looking for trouble Foowowee Can Am Racers, 917s, Etc. 18 10-03-08 01:58 PM
i`m in trouble now marshwiggle Introduce Yourself Here! 2 04-06-08 04:16 PM
Anyone ever have to trouble-shoot Smith's electronic speedo? Tom_Boy GT40 Tech - Chassis,Brakes,Tires,&Wheels 6 10-08-04 04:27 PM
