4.6 modular
IMRC intake manifold runner control.
I have a 4.6 modular with IMRC fitted.
This is a set of butterflys under the intake manifold to close off one of the 2 ports in the head.
I bought a manual in from USA but gives little info.
Have done searches on it but nothing thus far.
What I was after was a wiring diagram of the 96 cobra efi.
The other question is, under the manifold their is a motor that has the 2 cables coming out to open the butterflies, does anyone know if they use a PWM (pulse width modulation) to drive the motor.
Bottom line I will have little problem operating this with my Autronic ECU if I know how it works , a wiring diagram of the system would be a start.
Any help appreciated
Jim
under the manifold their is a motor that has the 2 cables coming out to open the butterflies...
Jim
Does two cables mean 4 wires to the motor, or does it mean that there is only two individual wires/copper cores to the motor.
if it has 4 wires it is likely to be a stepper motor and you will need to energize and de-energize the pairs of wires in a certain order to get the motor to operate
hope that helps.
will be good to se another RF on the road soon.
Sorry 2 cables meaning 2 throttle cables to operate the butterflies.
I recollect about 6 wires that why I suspect stepper (pwm)
Thats were the wiring diagram with pin outs from ecu to unit would be handy.
No silly errors.
Jim
index.php
The IMRC system has two intake manifold runners per cylinder for air flow into the combustion chamber. One runner is always open and the other is commanded open by the Powertrain Control Module (PCM). Below approximately 3000 rpm, the valve plates are closed and above approximately 3600 rpm, the valve plates are opened. The PCM also receives a signal from the IMRC system indicating valve plate position. The quantity of air metered to the engine is controlled by the throttle body assembly.
The IMRC system also has a housing and actuator assemblies. The IMRC housing assembly is an aluminum casting with two air intake passages for each cylinder. One passage is always open and the other is opened or closed with a butterfly valve plate. The IMRC Actuator is either a remote mounted electro-mechanical control actuator or a direct mounted vacuum actuator type system. In the remote system, the IMRC housing valve plates are held closed with a return spring located on the valve plate shaft. When commanded open by the PCM, the IMRC actuator pulls on the IMRC shaft assembly using an accelerator type cable. On the direct mounted vacuum actuator system, the return springs are located within the vacuum actuator. The PCM commands a vacuum control solenoid allowing the vacuum to pass to the vacuum actuator drawing the valve plates closed or releasing the vacuum allowing the actuator to push the valve plates open. Substantial opening and closing torque is applied in both systems. Care should be taken to keep fingers away from the lever mechanisms when actuated. It also provides a switch signal to the PCM for the plate position. This is the decription given in the ford service manual, Roy
