Go Back   GT40s.com > GT40 Technical Forums > GT40 Tech - Fueling and Electrics
GT40 Tech - Fueling and Electrics Petrol and Electrons.
Old 08-31-07, 06:52 AM   #1 (permalink)
huntsen's Avatar
huntsen
5 Tenths
GT40: Factory-built G
Rep Power: 11 huntsen is a splendid one to behold
Starter Motor
I'm in two minds whether to put this in Engines, but as it's a mechanical/electrical problem, it's going into electrics.
I have a problem with the pre-engagement solenoid in my starter motor. Normally, it engages and the starter spins the engine merrily until it fires.
Occasionally, usually when it's hot (and at the most inconvenient moment), the solenoid clicks and the starter doesn't engage.
This isn't a battery problem, as the starter spins quickly as soon as the solenoid can be persuaded to close properly.
My question is - Are the standard Ford starter motor solenoids dismantle-able and are parts available in the UK?
I hope it's just muck in the solenoid, jamming it up occasionally, but does anyone have experience of taking them apart?
Tony Hunt
huntsen is offline
Old 08-31-07, 07:22 AM   #2 (permalink)
ghur's Avatar
GT40: South Africa
Rep Power: 4 ghur is on a distinguished road
Re: Starter Motor
I had his problem recently on my CAV solenoid and it turned out to be internal corrosion on the terminals. I removed it and sprayed WD40 in through the starter to solenoid screw holes and after a few clicks it came right and has been ok since. The securing screws have sealant on the taper which wears off allowing moisture to seep in.
ghur is offline
Old 08-31-07, 07:31 AM   #3 (permalink)
David Morton's Avatar
David Morton
GT40: The Jewel on th
Rep Power: 35 David Morton has a brilliant futureDavid Morton has a brilliant futureDavid Morton has a brilliant future
Re: Starter Motor
Tony, I don't know if it's the same unit on mine but you can use it until you sort yours out. I think it's out of the car at the momet.
David Morton is offline
Old 08-31-07, 02:08 PM   #4 (permalink)
emiel
Silver Supporter
Belgium
GT40: kva mk1
Rep Power: 4 emiel is on a distinguished road
Smile Re: Starter Motor
Hi Tony,Ford starter motors are easy to dismantle and rather easy to assemble.But a Ford usa starter does not have a starter solenoid.The drive gear is put forward by one pole from the magnetic field which clics into the starter when it receives power.crude but it works.greetings Emiel
emiel is offline
Old 08-31-07, 02:30 PM   #5 (permalink)
huntsen's Avatar
huntsen
5 Tenths
Re: Starter Motor
Thank you for your detailed responses, gentlemen.
I don't propose to do anything immediately, as the problem is still intermittent and surmountable. But as the season will end in the next couple of months, I'll take it down over the winter and fix it for next Spring.
Many thanks,
Tony Hunt
huntsen is offline
