| Notices | Hi member,
Enjoy the forum!
Why not start with your first post today and become an active part of GT40s.com now! And, if you find you enjoy GT40s.com think about becoming a Forum Supporter. | | GT40 Tech - Powertrain/Transaxles Transaxles and driveline - don't dare post engine things here! |
01-29-08, 09:56 PM
#1 (permalink)
| | Bill D I Have No Life
Rep Power: 35   | I Think I'm Screwed - Again!!! I went to install the cross shaft that actuates the throwout bearing in my new ZF. I have two little white nylon bushings that are supposed to fit in the holes in the ZF case. The cross shaft rides on them.
Well, the cross shaft fits inside the bushings nicely, but the bushings fall through the holes in the case. Do they make thicker walled bushings that will fit? Or will I have to use an internal throwout bearing?
If the latter, then the $900 in clutch actuating parts are useless.
This build has become a nightmare with no end in sight.
__________________ Bill D
RCR GT40 Mk1 Gulf |
01-29-08, 10:05 PM
#2 (permalink)
| | chuck 1 8 Tenths
Rep Power: 12  | Re: I Think I'm Screwed - Again!!! I would think you could find suitable bushings either in poly or bronze, if push comes to shove, some machinist could make quick work of it.
__________________ chuck smith
CAV MONO GT40-302
SPF Daytona Coupe- Roush 427r
Kirkham 427 cobra- 427so |
01-29-08, 10:07 PM
#3 (permalink)
| | Jay P Rookie
Rep Power: 2  | Re: I Think I'm Screwed - Again!!! Bill, check out McMaster-Carr they have a several types of plastic and bronze bushings, both in inch and metric sizes. Type in "sleeve bearings" in the search field, and take your pick. John |
01-29-08, 10:18 PM
#4 (permalink)
| | jcdean Rookie
Hit up the local Vo-Tech school on the area. You have no clue how many little one off items I have had made for basically the cost of the material. Just place a call to the industrial arts teacher there.
__________________ Joey |
01-29-08, 11:00 PM
#5 (permalink)
| | Sandy Gulf GT40
Join Date: Jan 2003 Location: Los Angeles, CA GT40: RCR GT40 Gulf
Rep Power: 18  | Re: I Think I'm Screwed - Again!!! Man Bill you must be a lucky guy getting Screwed all the time ;-)
Check McMaster they will have something or something close that you can have a local machine shop turn down or bore. OR you can do an eMachine shop and have one made (will take a while) to your own specs.
Don't let this stop you, your close!
Sandy
__________________ RCR GT40 #11 348" Alloy SBF, 930 Box, Gulf 1075 Trim Now in the Garage, still under construction... www.gtsparkplugs.com Links to the cars |
01-29-08, 11:23 PM
#6 (permalink)
| | 7 Tenths
Rep Power: 17   | Re: I Think I'm Screwed - Again!!! Can you check the drawings for the assembly ? perhaps the bushings fit in cups and the cups are missing. |
01-29-08, 11:28 PM
#7 (permalink)
Rep Power: 35   | Re: I Think I'm Screwed - Again!!! No cups. The nylon bushings are supposed to slip nicely into the case and the shaft rides on the ID of the nylon bushing.
I'll try McMaster-Carr and if that doesn't work, I'll just park this nightmare
RCR GT40 Mk1 Gulf |
01-29-08, 11:38 PM
#8 (permalink)
| | Dlampe Silver Supporter
Join Date: Jun 2006 Location: Centralia IL GT40: RCR GT 40
Rep Power: 9  | Re: I Think I'm Screwed - Again!!! Bill, you are more dramatic than my wife!  Post some pictures and we can get you moving forward. If not, I really like my internal throwout bearing. Just a thought. |
01-29-08, 11:41 PM
#9 (permalink)
Rep Power: 35   | Re: I Think I'm Screwed - Again!!! My camera died. I measured the hole in the case and it's 7/8". The shaft OD is 11/16"
RCR GT40 Mk1 Gulf |
01-30-08, 12:00 AM
#10 (permalink)
| | Jay P Rookie
Rep Power: 2  | Re: I Think I'm Screwed - Again!!! Mcmaster has a bronze bushing, 7/8 OD X 5/8 ID. It would be a simple matter to bore the ID to 11/16. P/N 6391K202. $1.49 each |
01-30-08, 12:04 AM
#11 (permalink)
| | minerl Moderator
Join Date: May 2005 Location: Chewelah, WA GT40: SPF P2133
Rep Power: 5  | Re: I Think I'm Screwed - Again!!! Bill
Give me the EXACT dimensions of the hole and the shaft as well as the depth of the hole. I can make you some bushings with a shallow shoulder on one end that can press into the hole and a wide shoulder on the other side to lock it in.
__________________ Lynn |
01-30-08, 05:09 AM
#12 (permalink)
| | Canuk40 Supporting Vendor
Rep Power: 13  | Re: I Think I'm Screwed - Again!!! Hi Bill,
You may be missing a couple of needle bearings too. In the picture you can see the white plastic bushings, they sit on pads right beside the throw out bearing and protect the cross shaft from bending forces during clutch disengagement. The cross shaft rides in needle roller bearings that are pressed into the transaxle case. One end of the shaft stops within the bearing, the other end protrudes to attach the lever arm.
The plastic bushing are not used to support the shaft at the case. I'd find the needle bearings and confirm your plastic parts fit the location shown. Sorry, I don't have a part number or source for the bearings on hand. They will be metric parts by the way. Hope that helps.
__________________ Ian Clark
President
CAV Canada MotorSports Inc.
International: 905 637 9362 cavgtcanada@yahoo.ca |
01-30-08, 09:46 AM
#13 (permalink)
| | steve c Steve
Join Date: Jul 2005 Location: Boston, Ma GT40: SPF GT40 P2125
Rep Power: 7  | Re: I Think I'm Screwed - Again!!! Bill,
You are missing 2 needle roller bearings that should have come with the cross shaft TOB kit...RBT should be able to supply...Also I believe the white nylon bushes go in close to the fork arms to prevent wear of the fork arms against the stand offs...Make sense?
Steve P2125 with ext slave
ps I'd stay with the ext set up...hydraulics are a problem if leak |
01-30-08, 10:54 AM
#14 (permalink)
Rep Power: 35   | Re: I Think I'm Screwed - Again!!! Yes, it all makes sense now. I was hoping to install the engine and transaxle this weekend, but it appears I'll have to take the transaxle BACK to RBT for the needle bearings.
RCR GT40 Mk1 Gulf |
01-30-08, 11:25 AM
#15 (permalink)
| | Big-Foot Gold Supporter
Join Date: Jan 2007 Location: Minneapolis, MN GT40: RCR40 - #45
| Re: I Think I'm Screwed - Again!!! Quote:
Originally Posted by Bill D Yes, it all makes sense now. I was hoping to install the engine and transaxle this weekend, but it appears I'll have to take the transaxle BACK to RBT for the needle bearings. | I would check with the others on here that may have a stash of those bearings. Ron McCall? Ford? or just ask Lloyd to drop them in the mail to you (fat chance - I know)... You should also be able to source those bearings from a local Bearing Vendor as well.. |
01-30-08, 12:16 PM
#16 (permalink)
| | 2124 6 Tenths
Join Date: Jul 2004 Location: Rescue, CA GT40: Rescue, CA
Rep Power: 11  | Re: I Think I'm Screwed - Again!!! Perhaps someone can get the bearing numbers off them and post them here?
__________________ CAV #80, 331 Keith Craft, RBT Swift DB5 |
01-30-08, 12:34 PM
#17 (permalink)
Rep Power: 35   | Re: I Think I'm Screwed - Again!!! I just talked to Lloyd at RBT. He is shipping me the bearings, a freeze plug, a seal, and a picture how all of this goes together. He said it's relatively easy to install at home (HA!)
RCR GT40 Mk1 Gulf |
01-30-08, 12:41 PM
#18 (permalink)
| | steve c Steve
Good!...That's the way to do it...Freeze plug for far side bearing, seal to protect shaft side bearing ect...How about posting the picture Lloyd sends for all to see (I can't take pics of mine as it's all assembled) but, sure pic would be usefull to all.
Steve P2125 |
01-30-08, 12:54 PM
#19 (permalink)
Rep Power: 35   | Re: I Think I'm Screwed - Again!!! Will do.
RCR GT40 Mk1 Gulf |
01-30-08, 02:13 PM
#20 (permalink)
| Re: I Think I'm Screwed - Again!!! I don't mean to sound like a pessimist but I would not hold your breath on Lloyd shipping those parts to you... How long did you wait for your trans to be assembled after it was promised???
I would still pursue the part numbers / parts through other sources lest you be put on indefinite hold once again...
Sorry - but after all the horror stories I've read here I would never recommend anyone go to RBT. I'm glad that I am blessed with the skills and tools required to do my own work and what I don't have, I will fabricate or acquire as needed... | |
