Old 12th July 2010, 09:06 AM   #1 (permalink)
sdad
Pilot bearings needed?
While researching my Duratec 3.0L to 944 trans swap, I discover that the Ford Duratec/MX75 trans (transverse factory setup) does not use a pilot. I intend on using the Ford flywheel and the clutch parts from the MX75, as the clutch bolts up at the engine side and slides onto the 944 shaft at the trans side. I know that others have had pilot concerns with mating the 944 to other engines, but Ford has demonstrated that if conditions are right, a pilot is not needed.
So my question is, do I need the pilot? If so, why.
sdad is offline
Old 12th July 2010, 09:34 AM   #2 (permalink)
Eric Martin
2 Tenths
GT40: none now, planning one
Re: Pilot bearings needed?
You will probably need it for the 944 as it was designed that way. The Ford transaxle was designed to be supported internally so that it does not need a pilot bearing in the flywheel. If you don't use one you will most likely get alot of chutch chatter and the front bearing and seal in the transmission won't last long.
Eric Martin is offline
Old 12th July 2010, 10:22 AM   #3 (permalink)
sdad
Ah, thanks. Not the ideal answer as far as my work goes, but better to do it right the first time around. I hate redos
sdad is offline
Old 16th July 2010, 11:13 AM   #4 (permalink)
advancedautomotion
2 Tenths
GT40: I wish
Boxes with very short input shafts typically don't require a pilot bearing, however longer input shaft gearboxes do require them. I've got a few horror stories of people not running a pilot bearing on the 01E gearboxes.
advancedautomotion is offline
Similar Threads
Pilot Bearings / Porsche 930 to Ford Ron Earp GT40 Tech - Powertrain/Transaxles 6 29th May 2007 01:57 PM
Ford 289 bearings roberts66 GT40 Tech - Engines/Induction/Exhaust 12 4th April 2007 05:23 PM
Wheel bearings Russ Noble GT40 Tech - Chassis,Brakes,Tires,&Wheels 3 30th September 2005 01:39 AM
Transmission Bearings patbarry GT40 Tech - Engines/Induction/Exhaust 0 14th March 2004 11:04 PM
GTD rear wheel bearings Faili F GTD 40 Car Club Forum 1 11th June 2003 10:59 PM
