| SPF GT Chassis & Wheel Alignment Specs The following data is used for SPF GT general chassis specs and wheel alignment use.
General
Wheelbase 95” 2413mm
Track Front 55” 1397 mm
Track Rear 55” 1397 mm
Overall Dimensions
Length 168” 4265 mm
Width 70” 1778 mm
Height 40.5” 1028.7 mm
Miscellaneous Heights
Base of Windscreen 28.25” 717.5 mm
Top of Windscreen 39.2” 970.3 mm
Top of Steering Wheel 31.35” 796.3 mm
Minimum Ground Clearance 4” 101.6 mm
Static Wheel Alignment Specifications
Tires; Front: 225/60 15 Rear: 275/ 60 15
Ride height; Measured from chassis down at the wheels
Front 4” - 5” Rear 4 7/8”-5 ½”
Front Camber Negative .75 to 1 degree
Caster (non adjustable)
Toe Street out (neg.)3mm .120” total
Toe Track (suggested) in (pos.)1mm .039” total
Rear Upper Swing Arm length 825 mm 32.48”
Lower Swing Arm Length 785 mm 31”
Camber Arm length 255mm 10”
Camber Negative 1 to 1.25 degree
Toe Street out (neg)3mm .120” total
Tire Pressures
Street: Front 16- 20psi Rear 18-25psi
Track: Front 23-25psi Rear 28- 30 psi
__________________ Lynn
Reason: Spelling
