Old 04-07-07, 01:20 AM   #21 (permalink)
more_ghz_project's Avatar
more_ghz_project
Romania
GT40: i wish....
Re: GT40s.com Folding @ Home Team Formed
hi Alex,
here is my setup:
- intel pentium 4 2.4 Ghz
- XFX nvidia 6200 256 mb DDR II
- Kingmax 512 MB DDR 400 mhz
more_ghz_project is offline
Old 04-07-07, 01:36 AM   #22 (permalink)
xlr8or
GT40: None yet, that's next on the list.
I'm 3/4 done with the first one. Should be done by tomorrow afternoon.
xlr8or is offline
Old 04-07-07, 04:20 AM   #23 (permalink)
roaldin's Avatar
roaldin
6 Tenths
GT40: RF
Up and running on PS3 will check out other computers shortly.
Team 63884 but "donor name" just says PS3, is that ok?
Will get it running on my XBox360 as well if/when they support that.
Those watching this closely please advise when the 360 is supported.
Great idea!
Tim.
roaldin is offline
Old 04-07-07, 10:44 AM   #24 (permalink)
ahirsbrunner's Avatar
ahirsbrunner
Administrator
GT40: RCR-40 #24
Hi Tim,
You don't need to, but you can change the donor name to your ID (e.g. roaldin) on the PS3 under [Triangle button] options ->identity -> change donor name.
Al
ahirsbrunner is offline
Old 04-07-07, 10:48 AM   #25 (permalink)
roaldin's Avatar
roaldin
6 Tenths
GT40: RF
Thank's Alex,
Yeah I figured it out about 10 seconds after I posted the message.
About 2 hours to go on my first unit!
Tim.
roaldin is offline
Old 04-07-07, 12:40 PM   #26 (permalink)
Ron Earp's Avatar
Administrator
GT40: None.
Well I've got three machines up now but they are slow, taking a couple days to do a work unit. I will add a fourth machine Monday that should be a lot faster, and maybe a fifth next week. I hope they'll help a bit but you fellows with those PS3s ought to fire those things up!
R
Ron Earp is offline
Old 04-07-07, 12:41 PM   #27 (permalink)
more_ghz_project
Romania
GT40: i wish....
HELP !!!!
alex, dont live me here !!!
here is my setup:
Old 04-07-07, 03:06 PM   #28 (permalink)
ahirsbrunner
Administrator
GT40: RCR-40 #24
Hi Raca,
Don't worry, I'm going to install this version tonight and get back to you.
Al
Old 04-07-07, 06:26 PM   #29 (permalink)
ahirsbrunner
Administrator
GT40: RCR-40 #24
FYI - PS3 folks:
To run Folding whenever you stop using your PS3, go to the folding at home program icon, press triangle, go down to "auto-start" and choose what idle time you want it to start after.
Al
Old 04-07-07, 08:58 PM   #30 (permalink)
ahirsbrunner
Administrator
GT40: RCR-40 #24
Hi Raca,
I don't see the same problem when I install 5.03 on my PC, but there are two ways to solve the problem, the best for you is probably as follows:
Right click on the folding at home icon (the red molecule) in the system tray and select "configure".
Then on the display tab, check the box labeled "Turn on screen saver after x minutes" (e.g. 5 minutes). then also click "Run Core only when screeensaver is active". This way folding at home will not run unless the machine is completely idle for the amount of time you put in the "minutes" field. It may be the game is not being detected by folding at home and causing it not to halt. Let me know what games are causing a problem - I may have the same ones and can give it a try.
You could also click in the advanced tab of the configuration dialog and turn down CPU usage percentage until you find a value that works for you.
Al
Old 04-08-07, 05:04 AM   #31 (permalink)
more_ghz_project
Romania
GT40: i wish....
Hi Alex,
i did try to turn the CPU usage to minimum, but to no results
the games is have right now are:
Need for Speed Underground 2
and
Test Drive Unlimited
Old 04-09-07, 06:02 AM   #32 (permalink)
more_ghz_project
Romania
GT40: i wish....
the screen saver setting didn't work also
it stops folding, but when i open a game it sends it to the task bar
would a different version resolve the problem ?
Old 04-09-07, 11:56 AM   #33 (permalink)
xlr8or
WU one is complete. #2 is in progress. I installed on another machine as well. Going to add to a couple more.
Scott
xlr8or is offline
Old 04-09-07, 01:11 PM   #34 (permalink)
ahirsbrunner
Administrator
GT40: RCR-40 #24
Unhappy Re: GT40s.com Folding @ Home Team Formed
Hi Raca,
You already have the latest version installed. The only thing I can suggest is taking a look in the Folding at Home forums for the PC client to see if there is a solution posted there:
Folding-community.org :: View Forum - Windows NT/2K/XP/(Vista?) [CPU client]
Al
Old 04-09-07, 04:31 PM   #35 (permalink)
xlr8or
Ok, I have it running on a total of 5 machines now.
Hopefully that will help get the team numbers up there.
xlr8or is offline
Old 04-09-07, 06:38 PM   #36 (permalink)
Ron Earp's Avatar
Administrator
GT40: None.
I'm on four, but they are slow, about two days per work unit...
Ron Earp is offline
Old 04-09-07, 08:33 PM   #37 (permalink)
ahirsbrunner
Administrator
GT40: RCR-40 #24
Thumbs up Re: GT40s.com Folding @ Home Team Formed
Every CPU helps, slow or fast!
Cool! Only a few days of running an we are about to break into the top 10% of all teams. It's a steep road moving up from though, as the top team has 5 million work units under their belt (about 9000 CPUs)!
Thanks,
Al
Old 04-10-07, 01:26 AM   #38 (permalink)
xlr8or
I have 5 going now. three are P4's but the other two are older P3's. One of them is a Celeron so you know it isn't the sharpest pencil in math class.
xlr8or is offline
Old 04-10-07, 09:38 AM   #39 (permalink)
Neal's Avatar
Neal
GT40: GT40 NZ
I'm in with one machine. Another on the way.
GT40 NZ - 347 / Webers / Red and White -
FFR Roadster #4867 408 / TKO / 3-Link
Neal is offline
Old 04-11-07, 02:54 AM   #40 (permalink)
more_ghz_project
Romania
GT40: i wish....
i'm very HAPPY last night i just finished my firs Work Unit !!
i manged to do it faster than what the program predicted by Overclocking my CPU from 2.4 ghz to 3.1 GHZ
now i have an ET of 43 hours till the next WU is done
now i have a good excuse to keep my PC on 24/7 ....... ARRRGHH !
LinkBacks (?)
LinkBack to this Thread: http://www.gt40s.com/forum/paddock/21347-gt40s-com-folding-home-team-formed.html
Posted By For Type Date
GT40s.com This thread Refback 04-04-07 12:11 AM
