Guys,
I have piece of 2024-T3 .090" sheet that is literally perfect for the project I'm working on. However, I need to bend it 90 degrees in my Roller-Brake with a 3/4" radius. The two bends are to be 9" apart from one another and parallel.
Bu using liberal heat and a lot of BEEF I have made one bend, but need to make the second. The piece is now no longer long enough to clamp in the brake by normal means (which was barely sufficient to make the first bend) and so I will need to rig up another means to clamping. Certainly the rigged clamps won't be as stout as the ones on my bender.
SO
What I would like to do is to soften up the metal sufficiently where I can make this bend without requiring herculean strength to do it..
I've softened up other alloys in the past by heating and then quenching. This stuff seems to retain it's strength quite well... Unfortunately..
Any tips for me?
I'd really like to get this project knocked out this weekend and with recent health issues I can't drive to go find more material..
Thanks in advance...
Alloy info;
http://asm.matweb.com/search/SpecificMaterial.asp?bassnum=MA2024T3
SO
Any tips for me?
Alloy info;
