Old 10-29-05, 05:25 AM   #1 (permalink)
Chris Liokos's Avatar
Chris Liokos
7 Tenths
GT40: RF40
Rep Power: 15 Chris Liokos will become famous soon enough
Brake pad replacement
Can somebody please jolt my memory as to how to get the front brake pads out of the PBR calipers? I know that you remove something and the caliper then pivots away from the rotor, but what do you remove and which direction does it pivot? Its been nearly 4 years since I fitted these things... frightening to think how quickly time has gone by [img]/ubbthreads/images/graemlins/grin.gif[/img]
Chris Liokos is offline
Old 10-29-05, 02:06 PM   #2 (permalink)
Hershal Byrd
GT40: RF
Re: Brake pad replacement
Chris,
I usually take both bolts out that holds the caliper in place. Then I remove the old pads and use a C clamp to push the caliper piston back. Then stick in the new pads and bolt it back in place.
Hershal Byrd is offline
Old 10-29-05, 02:09 PM   #3 (permalink)
Chris Liokos
7 Tenths
GT40: RF40
Thanks Hersh. Seems my memory is playing tricks on me [img]/ubbthreads/images/graemlins/smile.gif[/img]
Old 10-29-05, 04:06 PM   #4 (permalink)
David Morton's Avatar
David Morton
GT40: The Jewel on th
Rep Power: 36 David Morton has a brilliant futureDavid Morton has a brilliant futureDavid Morton has a brilliant future
And probably monitor the fluid level as you compress the pistons as well.
David Morton is offline
Old 10-29-05, 04:11 PM   #5 (permalink)
David Morton
And probably best to monitor the fluid level as you compress the pistons as well. I made that mistake last week on my Explorer and looking back on maintenance done in Italy, the garage had topped up my reservoir early in the summer - which I hadn't noticed so when I came to replace the pads on thursday - like the fountains of Rome.
Old 10-30-05, 01:03 AM   #6 (permalink)
Chris Liokos
7 Tenths
GT40: RF40
All comes back to me now. Here is the method for future reference.
Remove circlip and washer from the lower retaining pin, then withdraw pin.
Old 10-30-05, 01:05 AM   #7 (permalink)
Chris Liokos
7 Tenths
GT40: RF40
Pivot the bottom of the caliper away from the disc.
Old 10-30-05, 01:07 AM   #8 (permalink)
Chris Liokos
7 Tenths
GT40: RF40
Withdraw the caliper totaly for access to the pads from the inside.
Old 10-30-05, 04:03 AM   #9 (permalink)
ross nicol's Avatar
ross nicol
Good Michael Jackson impersonation Chris.LOL
Ross
ross nicol is offline
Old 11-01-05, 09:58 AM   #10 (permalink)
Chris Liokos
7 Tenths
GT40: RF40
I do a pretty good michael jackson "Woo Hoo" and dance when I touch the hot brakes without gloves too [img]/ubbthreads/images/graemlins/grin.gif[/img]
