Old 11-07-06, 07:58 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
ross nicol's Avatar
ross nicol
Rear caster error in measurement
Couldn't open the bump steer thread so had to slip in a new one. Have a read of my digital level thread in the tech chassis section and you will understand why I have posted this correction to measured rear caster on my car. What I thought was 7 degrees turns out to be 5.1 to 5.3 degrees. I humbly apologize for any inconvenience this may have caused.
Ross
RF #025 currently racing
ZF,Motec injection
Lotus Europa S2
De Tomaso Pantera
ross nicol is offline
Old 11-08-06, 08:33 AM   #2 (permalink)
Chris Liokos's Avatar
Chris Liokos
7 Tenths
GT40: RF40
Rep Power: 14 Chris Liokos will become famous soon enough
Re: Rear caster error in measurement
I'm having the same problem with the bump steer thread but I believed my error message when it told me that it was my cache administrator
Anyway, I was never really sure how to measure rear castor. Is it along the plane of the reverse-a-arm or do you use an imaginary line drawn vertically along the centre of the upright or what? And is it relative to the ground or the chassis? There are many other options too and anyway, however you measure it, it changes dynamically doesn't it? Someone once even insisted that the term “rear castor” is meaningless because without steer there is no castor (but I think we all know what we mean).
RF40
Chassis No 18
302W
Chris Liokos is offline
Old 11-08-06, 03:38 PM   #3 (permalink)
ross nicol's Avatar
ross nicol
Chris
I use my digital level on the machined area on the rear of the upright, it has 2 threaded holes.This surface is 90 degrees to the horizontal so makes the caster a direct reading ( when I read the correct scale that is).
Ross
ZF,Motec injection
Lotus Europa S2
De Tomaso Pantera
LinkBacks (?)
LinkBack to this Thread: http://www.gt40s.com/forum/roaring-forties-gt40s/19768-rear-caster-error-measurement.html
Posted By For Type Date
GT40s.com This thread Refback 11-08-06 10:54 AM
Similar Threads
Rear suspension bump steer Jim C GT40 Tech - Chassis,Brakes,Tires,&Wheels 94 06-04-07 11:07 AM
rear suspension caster cudabeen GT40 Tech - Chassis,Brakes,Tires,&Wheels 8 11-08-06 03:30 PM
Deflection Figures for a GT40 Chassis James GT40 Tech - Chassis,Brakes,Tires,&Wheels 77 08-29-05 04:55 PM
Designing rear anti-roll bar brackets for my RF Mark Worthington GT40 Tech - Chassis,Brakes,Tires,&Wheels 27 08-26-04 12:54 PM
Where do cables go through rear bulkhead John Lind Roaring Forties GT40s 2 03-03-02 06:05 AM
