RE noisy dampers, I've recentley cured damper noises on my Lotus & some of this may be relevant.
Firstly, The Lotus chassis is extreemley stiff & one of the spin off's of this is that it transmits road, mechanical noise very well! combine this with no carpets or soundproofing & you can hear all sorts of mechanicals you can't hear in a 'normal' car.
Caterhams & Westfields also suffer the same.
Early cars suffered from the standard gas dampers 'knocking'. There was nothing wrong with the damping, just the fact that it made a noise that could be heard in the cockpit & sounded like something was loose.
Since changing to oil filled adjustable dampers, I've experienced 'squeeking', extreemeley loud & high pitched. Not nice!.
It took me some time to track the noise to the dampers, which were sent back to the manufacturers (Leda) for re-valving & servicing. They told me the noise is caused by the adjustable valve & by replacing it the noise was cured.
So the moral of my story is that there is more to damping than meets the 'ear' & in every car on the road there are all sorts of mechanical noises going on that we don't normally hear due to all the sound proofing engineered into the vehicle. In 'our' field comfort is compromised to improve performance!
Hope this helps!
