351 SVO SIAMESE BORE, DRY SUMP BLOCK, M-6010-R351*
*(not for use on pollution controlled vehicles) hee hee
9.200" Deck height
Cast iron w/ 4 bolt main caps (looks like all 5)
Nodular iron main caps
Can be bored/stroked to produce 427 cu in.
Siamese cylinder bores
Bore range from 4.000-4.125"
Dry sump oiling design
2.749" main journal diameter
wieghs approx. 190 lbs.
High strength block for professional competition
Semi-finished lifter bores, must be honed to fit
This was taken from the 1999 Motorsports SVO catalog
hope it helps.
