Guys,
I had to make the mounting pieces for the steering column in my Sabre. The pieces go into a 1x2" piece of box tubing that spans the to front center of the structure for the front of the driver's compartment.
Fabricating this piece was a pain because it involved milling a 1 1/2" hole into split aluminum bars at an angle. The piece came out perfect as to angle and fit to the column.
Unfortunately, the column is now 1/4" to far to one side as the hole should not have been in the center of the hole for the mount ... as I assumed that it would need to be. This causes the dash to be off center which would cause the spyder to be off center in the front.
So ... I either remake the piece, or weld up the holes and one side of the ledges and recut them so that the mount is properly off center.
Has anyone done any MIG welding on 6061? Is this approach worth trying?
Thanks!
Thanks!
