Rick Merz
For Sale 1995 GTD GT-40 S/N GTD40P21390
This car was built with attention to detail and to perform equally well in city traffic or going all out on the track. This car will keep you cool in 95° stop and go city traffic without over heating and will turn 11.7's @ 125mph in the 1/4mi. The only thing that will hold this car back on a road course is driver experience; with a good driver it will run at the front of the pack. The current engine was installed on July '03 and has 1,900 miles on it. The tires were changed Sept '03. Current paint job and new stainless steel panels were installed January '04. The suspension bushings and springs as well as new brake pads were changed February '04. The interior carpet was changed March '04. The AC system was completely evacuated and recharged with a new receiver drier April '04 (I had to open the system when I replaced the aluminum panels with stainless steel panels). This car has been pampered (has it's own 2 1/2 car carpeted and climate controlled garage), and maintained to the highest standards and is always ready to drive or race at a moments notice. I am selling my car because I will be retiring to Huatulco Mexico next summer and I will not be able to drive it on the local streets with their 5" speed bumps and there are no tracks that it could be run on without traveling 2,000 miles. I am asking $65,000 (USD), which is a very realistic price for this very well built car. It would be very difficult to build or purchase a GT40, get it sorted out so that you can enjoy it with out getting stranded somewhere and perform as well as my car for less than $85,000 plus a couple of years of labor. Someone will have the chance to take advantage of my situation and save them self over $20,000 plus a couple of years of labor and start enjoying this GT-40 today. I have almost all of the receipts for the parts and labor that went into this car but I am afraid to add them up; however the new owner might find it interesting to do. If you want any further info include your phone number so that I can call you, I am not a typist and I have already worn out my fingers just putting this information together.
Press / Shows: Cover Car and feature article Kit Car Illustrated October '99 as well as being included in several other articles in later issues. Entered 8 shows, won 3 best of show, 7 first place and 1 best engine.
Body / Frame:
GTD supplied complete kit with body panels of fiberglass and tube frame.
Body was delivered in red gel coat. Body was then fit, sanded, pin holes filled, primed, more filling and painted 2002 Corvette red. Current paint job was completed January '04.
Frame came power coated red from GTD and is as delivered from GTD with the exception of being modified to house a 351W mated to a Porsche G50-52 transaxle mounted as low as possible to get the best possible center of gravity and half shaft angles.
Engine:
On a chassis dyno this engine made over 420hp with over 430ft/lb of torque at the wheels.
Ford Motorsport M-6009-A392 short block.
Heads: World Products cast iron Windsor Jr. with stage 2 porting and port matched to the intake manifold and the exhaust header flanges.
Induction: Assembled, detailed and set up by Ingleese, (4) 44mm IDF Webbers powder coated red with chrome screws and hardware mounted to a 302 manifold with spacers for use on a 351W. Manifold spacers have the added benefit of a longer induction runner which increases torque. Aeroquip stainless steel braided lines and aluminum fittings used throughout the fuel system.
Cam: Comp Cams #35-522-8.
Valve Train: Compcams roller lifters and roller rockers.
Cam Timing: Edelbrock Accu-Drive gear drive #7892.
Ignition: Electromotive HPV-1 crank trigger with 4 coils (no distributor).
Wires: Taylor Spiral Pro.
Oil Pan: Canton racing.
Oil Cooler: Moden.
Crankshaft Damper: Ford Motorsport M-6316-C351.
Headers: 4 into 1 non-bundle of snakes, Jet Hot coated and wrapped with Thermal Tech tape.
Mufflers: Custom made polished stainless steel.
Starter Motor: High Torque #101.
Drivetrain:
Transaxle: Porsche G50-52 5 speed with Quaife LSD and race-hardened gears built by Powerhause. Transaxle has been modified to run inverted and has 6 jets that spray oil on all 5 forward gears as well as the ring gear.
Clutch Pressure Plate: KEP high performance clutch made from billet aluminum (housing), that will hold 650 ft/lb of torque.
Clutch Disc: Porsche high performance disc.
Tilton Master cylinder with Porsche slave cylinder.
Shifter: Patrick Motorsports cable shifter PMPG50CS.
Flywheel: KEP custom made for 351W to G50 conversion.
Oil Pump: Tilton #17-522 which provides 2 gal / min @ 50psi.
Aeroquip stainless steel braided lines and aluminum fittings used throughout the transaxle oiling system.
Oil Cooler: Moden.
CV Joints: Fat Performance Porsche 930.
Axles: Fat performance Saw drive axles Porsche 930 CV 17 1/4" long.
Suspension / Brakes / Wheels / Tires:
Tilton master cylinder without booster.
Front: Wilwood 4 pot calipers clamping 13" curved vane rotors.
Unequal length control arms chrome plated as supplied from GTD with new poly bushings.
Spax adjustable coil over shocks with new 275lb. springs.
Standard sway bar as supplied from GTD.
Image 6 spoke 17" x 9" 3 piece with Yokohama AVS sport 255/40ZR17 tires (new).
Rear: Wilwood 4 pot calipers clamping 13" curved vane rotors.
Unequal length control arms with upper and lower radius arms chrome plated as supplied from GTD with new poly bushings.
Spax adjustable coil over shocks with new 350lb. springs.
Sway bar is 2mm larger than standard GTD sway bar.
Image 6 spoke 17" x 11" 3 piece with Yokohama AVS sport 315/35ZR17 tires (new).
Misc.
Electronic VDO speedometer that can be recalibrated for any wheel / tire or rear axle ratios.
RCI 5 point harness for both driver and passenger.
Radiator has been reworked to provide more engine cooling.
Dual Spal fans VA01-AP6-36A (as used on NASCAR) pull air through the radiator.
Oversized ac condenser mounted in front of the radiator for improved ac performance.
140amp one wire alternator provides plenty of power to run the fans, lights, AC and stereo at the same time.
Optima (yellow), high capacity battery (with 7 years left on the warranty), with custom stainless steel battery box.
Car has full flow lemans style nostril.
JVC Kamillon am/fm/cd player in dash and 4 Blaupunkt speakers in each door.
Modifications were made to the foot well / pedal assembly and the body / interior tub area to provide more head and legroom to accommodate a 6'-2" driver. I am 6'-2" and can fit comfortably in this car. If you are taller than this you may have problems fitting in this car (or any GT40, hello they are only 40" tall), with a helmet on.
For more info contact me at [email protected] or call 757 494-2137 (work), 757 474-3663 (home) after 1pm.
Body / Frame:
Engine:
Oil Cooler: Moden.
Drivetrain:
Oil Cooler: Moden.
Misc.
