ERA Mk I 2087 car was buffed, polished, and waxed. Period correct FORD Guardsman Blue with a Racing White painted stripes. This is an LHD ERA stainless steel monocoque model with built in roll bar. This beautiful Mk I example has front canards.
The car is in Wisconsin. VIN# ERA2087.
In addition to other ERA cars, this car has added front structure reinforcement that now allows the front of the car to be raised with the traditional lifting jack. The added front tow bar is also designed to allow the car to towed/tied down without fear of damaging the chassis or painted body panels.
Power plant: Dart 390 cubic inch topped with 4- polished WEBER 48 IDA carburetors feed by selectable dual fuel pumps. Engine is fully forged approx. 575HP. It's outfitted with: full polished Cobra intake, MSD ignition ensemble, bread box style valve covers. Fuel-delivery arrangement is designed to be a circulating system... therefore, no vapor-lock issues. The setup is designed with a Pollock valve which returns the fuel to the correct tank. Fuel system has a pre-and post-pump filter to prevent carburetor clogging. Dual cooling fans with manual override activation switch. Custom-formed Silver ceramic-coated "bundle of snakes" header exhaust system, with the optional insulated SS [stainless steel] heat shield located on the inside of the rear clamshell.
The Gear train: McLeod clutch equipped with a rugged RBT/ZF 5-speed polished transaxle with rod shifter linkage modifications.
Rolling stock: 15" magnesium halibrand wine glass style from the UK pin-drive knockoff wheels fitted with Goodyear Bluestreaks
Suspension, braking particulars: Independent double trailing and transverse links and inverted A-frame wishbones rear, offset A-frame wishbones and front/rear Wilwood brakes. Full in dependent adjustable front & rear coil-over suspension with H&R springs and Spax shocks.
In the cockpit: Period correct SW gauges: black suede upholstery, quick-release suede steering wheel and Gt40 leather wheel with traditional FORD center hub:
It has black willans harnesses for both driver & passenger. Internal Fire Suppress system with cabin and engine nozzles. Also, High-capacity air conditioning. Lucas old new stock rear double lights, cibie headlights, slotted rear plexi.
It is fitted with adjustable-pedals foot box.
Other particulars: dual Raydyot style racing mirror, and Lucas 608, and front sway bar and extended rear sway bar links. Twin impact resistant 8-gallon fuel tanks are located in aluminum cradles filled with ant slosh/anti-flame propagating foam. No carpet. Side air scoops on driver and passenger window. This ERA is very well sorted out (~1500 miles) and fully prepared for your motoring adventures; engine is new, it's in great condition. $170,000 firm. I will take more pics when I can get car outside. WOULD DO POSSIBLY TRADE DEAL WITH CSX 289 FIA, ERA 289 FIA, OR KIRKHAM FIA.
