Finally got an answer back from the Florida Lucas switch suppliers, their down in Hurricane alley and still recovering. The Lucas switches are rated at 20 amps.
""Do you have the Lucas wiper motor?""
No, it's
www.SpecialtyPowerWindows.com just the basic 2 speed, no intermittent.
""I have a twin relay circuit for this and it works well and parks the wipers at the fast speed, even if they were running on slow speed. Something different I get a kick out of that. If you want the circuit let me know.""
Sure, let's see it
""I'm ok on Map based engine management tuning now too. Constructed my own wide band Lambda meter from a kit.""
Is that a Techedge system? Does it do the closed loop with your Motec? I'm envious of the Motec, it's out of the budget range here in the states. The main thing the GEN7 doesn't have that may be desireable is a VSS input.
""Let me know if I can help more with the electrics guys very willing to help.""
hope you don't come to regret that statement 8>
Another question, I've seen stereo amp (large) main power wires that are run across or very near to factory ECU's cause weird problems, like multiple random trouble codes etc. I would like to run the main + battery cable (battery in front) down the center of the car within 6 inches or so of the ignition and wide band controllers and near the smart coils. Should I just avoid this altogether and run the positive cable elsewhere? Is there some general separation distance or do you think the cable going to the starter is even going to do the same thing as a big amp stereo main power wire?
Is this RFI or electro-magnetic interference? Accel does warn you about RFI from secondary ignition but nothing about large positive wires.
I'm also working on a cad drawing of the more complex and relayed circuits and when done would like to post it for critique.
