gear linkage
Lynn Larsen
Lynn Larsen
Frank,
Just a dumb question, I guess, but have you looked at the Pantera shifter setup? It should be exactly what you need except for the possibility of different lengths.
Lynn
Ron McCall
llarsen said:
Frank,
Lynn
Except that the Pantera shifter box is also on the left side.The GT40 would be on the right because the box is inverted.
Ian Clark
Frank Beuker said:
i've got it on the right side and i wanted to see how they did it with the alternator
Hi Frank,
Our ZF Shifter Upgrade for CAVs will fit most other brands so why not give me a call on the toll free tech line 866 278 GT40 (4840) and we'll sort you out.
Thanks Ian I will
I'd allready looked at the pantera but there the shifter goes down underneath the block out of the way of the alternator (íts on the other side)
and the engine is much higher up
i'mjust looking at the angle's of the rod's and the chairs
Frank
