I'm building my RCR40 with a Small Block Ford 331 Stroker and Porsche G50/03 Transaxle. At the point in time when I started building this car, there were no other RCR owners on the forum that were building with Porsche G50 transaxles.
I moved my engine/transaxle forward by a little over 2" in order to more closely align the rear axles to the axle stubs on the transaxle as well as to get the back end of the transaxle "inside" the rear body work.
When I moved the engine/transaxle forward, I found that I could not fit the stock HD Porsche starter as it would hit the chassis. The starter needed to be re-clocked in order to work.
There were no commercially available starters that could be re-clocked that I could find.
I found a gear reduction starter on eBay and another RCR Builder (Jeff Hamilton) had bought the same starter to go through a similar exercise on his RCR40.
This picture shows the stock starter and the interference with the chassis;
The problem with re-clocking the stock starter is that it has a shrouded nose that has an additional bearing - so I sourced this Gear Reduction starter that had a fully exposed drive gear:
Here you see the factory Clocking
This picture shows the desired Clocking
Houston - we have a problem… The bolt (actually one of the 4 10mm transmission mounting studs) is a mile away
Here you see where the other bolt needs to be;
Metal in the bellhousing is quite thin here but we'll make it work by threading a button head bolt through from the inside;
So I start designing a dual-purpose torque strap that will also clamp the starter tight to the bellhousing;
And here - We have Crankage…. It works quite well! No movement of the starter and good engagement of the gears.
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/RfKwaAPM0Bs&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/RfKwaAPM0Bs&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
PLEASE NOTE::
Not long ago - RCR has sourced re-clockable starters that are available.
I hope this information can be of some use to someone who needs to re-clock their starter..
PLEASE NOTE::
