Thought this might help someone else - The ECM coolant temp. sensor goes into the drivers side forward engine head near the exhaust manifold port. There is a similar plugged port on the passenger side at the rear of the head. I found a direct fit Koso sensor that can be used for the KOSO dash gauge package re: for water temp. readings.
Koso: BF120000 0-250* with JST connector M12XP1.5 I ordered it direct from Koso Canada and received it several days later. My water temps appear more accurate than the engine block location previously used. BTW: do not use a crush washer on it - 1st try it leaked. Removed washer - use some thread sealant and done.
