Michael Fling
Does someone have the specific Setrab part # for an oil cooler that will fit on the drivers side inlet?
This should solve the problem:
1. Oil Accumulator Adapter for LS Engines. Oil will constantly run from this adapter.
2. Then it will run it to a thermostat like this Mocal unit:
BAT, Inc. - MOCAL Oil Coolers
3. Then run the lines to and from the thermostat to the oil cooler.
4. On the line running out of the thermostat back to the engine, plumb in the t-check valve and the accusump.
Now.. if anyone has the Setrab model I would appreciate it.
One is more than sufficient. There would be less plumbing if you mounted it on the drivers side. Be sure to add a thermostat control valve. Many C6 Corvette owners complain that in the spring and fall in cooler temperatures their oil doesn't get up to temperature with a remote cooler.
